X pipe questions
Old Sep 6, 2009 | 12:10 PM
ChevyTruck's Avatar
something else
Question X pipe questions
Is there a advantage to the X pipe on true duals?
Does it help the flow of the exhaust flow?
Does it make the sound any louder?
Old Sep 6, 2009 | 12:23 PM
budhayes3's Avatar
PT's Slowest Truck
X-pipe will help to balance out the exhaust pulses and will help with scavenging...some sort of balance tube, wether it be and X or H pipe is recommended. From what I've heard, and X pipe will actually decrease the exhaust sound some...
Old Sep 6, 2009 | 12:26 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
X is the best way to go. What it does is use the exhaust pulse from one bank to pull exhaust from the other (scavenging). The older H pipe technology does the same thing less efficiently. You want your X as far forward as physically possible.
Old Sep 6, 2009 | 12:36 PM
ChevyTruck's Avatar
something else
Would it help on performance at all?
Old Sep 6, 2009 | 01:58 PM
Mangled03gmc's Avatar
Baltimore Whore
It will help out some. Like stated it makes the exhaust work better. Anytime you can make flow more efficient, you free up hp...
Old Nov 2, 2009 | 12:30 AM
FrankyRST's Avatar
So i was talking to some buddies about this today and i got curious so id thought id search for some info on pt.net
so the closer to the tips the better?
Anyone else have anymore info on any benefits or tips on putting an x pipe on true duals?
Old Nov 2, 2009 | 01:51 AM
zachm89's Avatar
no, as close to the headers/cats as possible...i have an x-pipe on my SSS with dual magnaflows and it didnt really make the exhaust any quieter but it definitely made it alot more smooth sounding, took out the rasp completely. i would definitely recommend installing an x pipe on a true dual setup
Old Nov 2, 2009 | 08:25 AM
trever1t's Avatar
^ as far forward as possible.
Old Nov 2, 2009 | 11:28 AM
budhayes3's Avatar
PT's Slowest Truck
+1...Trever1t has the perfect exhaust set up IMO...
GXPJAY
Feb 13, 2022 08:15 AM
KEV5.3
Aug 24, 2015 08:00 PM
USMCvet0311
Aug 1, 2015 07:45 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
