Would you cut stock airbox again
Old Oct 8, 2007 | 12:34 PM
  #21
BlackGMC's Avatar
Resident Retard
Originally Posted by mcphck
BlackGMC, is that intake going to a cutout where the foglights are? And then up through the fender to airbox right?
Yep! When I clean my K&N it has a big black spot where that air hits it from the ram-air tube... I have driven this setup in pouring rain and never had a problem with water getting in the intake... One of these days I will redo it with steel pipe, it is kinda embrassing everytime my truck gets put on a lift...
Old Oct 8, 2007 | 12:46 PM
  #22
jknox's Avatar
Heck, I've just got flexible drain hose run for mine - doesn't embarrass me in the least. Actually I've had several postive comments! One thing I do want to do though is fab up a better scoop for the tow hook opening.
I don't know how much difference it really makes performance wise, but you can see a real difference on IATs. After parking for a bit I can easily have IATs in excess of 125. Before the tube it would take forever for the temps to drop back under 100 - now it's usually before I'm out of the parking lot.
Old Oct 8, 2007 | 12:50 PM
  #23
BlackGMC's Avatar
Resident Retard
I agree, it helped my IATs alot, however I might have gained a small-hill-billy-sized-butt-hair worth of performance out of the scoop, and that is only at 60+.....
Old Oct 8, 2007 | 01:18 PM
  #24
agreif's Avatar
Anyone have a pin hole drain in their ram tubing or do you not worry about any moisture. I guess as long as you always have some slope downwards you should be ok as it won't really be able to make its way all the way up the hose into the airbox.
Old Oct 8, 2007 | 01:50 PM
  #25
XLR8NSS's Avatar
Adkoonerstrator
Originally Posted by agreif
Do you mean the foam on the outside passenger side, the part that seems to isolate the fender air from the engine bay air?
No, the 1/4" or so thick stuff directly behind the headlight. I'll snap a pic a little later and post it up.
Old Oct 8, 2007 | 08:00 PM
  #26
agreif's Avatar
ahh, I think I know what you are talking about with the the foam, it's that black flimsy stuff behind the headlight, I woudl be curious to see the airbox cut though.
Old Oct 10, 2007 | 08:45 AM
  #27
OnyxSilveradoSS's Avatar
here is my attempt using a volant snorkel
http://www.silveradoss.com/forums/in...howtopic=22613
Old Apr 14, 2008 | 08:12 PM
  #28
tooquick2beslo's Avatar
Originally Posted by BlackGMC
Homemade Lid/Intake
Wondering what you used for this intake tube ? Can you give me a parts break down and where you got the material from ? Did you get them from a local home depot or lowes ? I am interested in just doing the tube.
Ps. sorry for bumping an old thread.
Old Sep 21, 2008 | 05:45 PM
  #29
LARRY01Z28's Avatar
old threads are great. always good info every where. im gettign ready to do the same set up on my new truck.
ARC
57
Feb 21, 2022 10:54 AM
BennyB
Aug 1, 2015 08:48 AM
BIGD4504
Jul 28, 2015 11:46 AM
black6spdz
Jul 16, 2015 01:32 AM
Chiphead
Jul 13, 2015 10:16 PM
