would a cam fit this big
Originally Posted by javier4.8
its the The Texas Speed Torquer 2 232/234 .595/.598.. and with my choice of lobe seperation.. 112,113,114.. and the kit has the 918 springs and the pushrods.. and im going to get a tune from them and im going to run the ls1 heads too..
for you with your 4.8 your limit is around 224!!!!
Wow ... even by my standards, that's WAY to much cam for a 4.8. I ran a 233/239 in a stock headed 5.3 as a DD. It was fine once it was tuned, but it took a while to get there. I would do it again, but I would prefer to have some better heads and a couple other little odds and ends.
I'd say stick with something like a 224/224 112 or something similar to that. Even with a stock converter, that cam will be fine, most will disagree, but of course, that's them and not me. You're not going to really 'loose' low end with something that size, the mid and upper is going to be exponentially better than before which will make the low end seem lacking. To each their own though.
I got all kinds of stares going through a parking lot or just sitting there idling for that matter.
