Wiring schematic??
Old Aug 6, 2003 | 04:21 PM
GoldenVelvet's Avatar
Default Wiring schematic??
can anyone help me figure out the five wires going into the fog light/cargo lamp switch. I have the switch for the fog lights but no fog lights and I want to wire the switch as a momentary.
The five wires going into the switch are Gray, ornge, black, blue, and purple. I want to push the button for fog lights and have something turn on for only the time I have the button pushed in.
However I still want my cargo lamp to work.
Old Aug 7, 2003 | 01:12 PM
Default Re: Wiring schematic??
anyone? I feel so unloved.
Old Aug 7, 2003 | 01:57 PM
JSmith's Avatar
As far as I know the fog light switches or on/off only and won't do momentary.
Old Aug 7, 2003 | 03:09 PM
GnatGoSplat's Avatar
If this is 99-02, the foglight switch is momentary between orange wire in terminal "G" and Ground.
Old Aug 7, 2003 | 03:39 PM
Thats what I thought, the foglight button is momentary and just sends a signal to the BCM, normaly. but, if I re-wire the ornge wire to my own relay then it will be momentary. The black is ground I assume.
Old Aug 7, 2003 | 05:06 PM
JSmith's Avatar
I guess that goes to show what I know.
Old Aug 8, 2003 | 04:22 PM
Yes, black is ground. You're right about the foglight button being momentary and sending a signal to the BCM. That's why trucks without foglights need the BCM reprogrammed when factory fogs are added.
Old Aug 8, 2003 | 04:28 PM
Banned
is there anywhere on the web with a wiring schematic for our trucks that i could print out?
Old Aug 8, 2003 | 04:52 PM
ArizonaSpeed's Avatar
I can fax you some copies of certain diagrams if you need them. Just let me know.
Old Aug 8, 2003 | 07:05 PM
GREGGO's Avatar
This is all I could dig up:
Fog/Cargo light schemtic
