is this the wire.
Old Jun 28, 2006 | 11:40 AM
ltn's Avatar
ltn
Default is this the wire.
the wire for the a/c for electric fans is the dark green on with a white stripe? is that the one and it comes from the wire loom that is running down next to the engine next to the red jump box. O yeah this is for the nelson wiring harness. thanks
Old Jun 28, 2006 | 12:48 PM
TXsilverado's Avatar
theres 2 green wires...mine was the green wire that matched the harness exactly
Old Jun 28, 2006 | 01:38 PM
ltn's Avatar
ltn
ok because i know mine has a dark green wire and then a light on. i believe the dark green one also has a white stipe on it. Hey Txsilverado if you get time could you check which one u tapped into. thanks.
Old Jun 29, 2006 | 10:10 PM
Gmc²'s Avatar
let me know which one as well.
light green or dark green?
Old Jun 29, 2006 | 10:35 PM
Colby 04's Avatar
It's the dark green one...
Old Jun 29, 2006 | 10:38 PM
blue 01's Avatar
I'm pretty sure it is the green one with out a stripe. You can check it with a voltage meter.
Old Jun 29, 2006 | 10:42 PM
Colby 04's Avatar
Originally Posted by blue 01
I'm pretty sure it is the green one with out a stripe. You can check it with a voltage meter. It is a ground when the compressor is on. I would go look but it is all taped up.
I would go look and take a picture, but I just took my shoes off
Old Jun 29, 2006 | 11:09 PM
ltn's Avatar
ltn
thanks colby... hey what kind of fans do u have, does it keep ur car cool in texas?
Old Jun 29, 2006 | 11:18 PM
Colby 04's Avatar
LS1 fans....I haven't had any problems yet.
ReSpAwN DeMoN
May 6, 2007 11:14 PM
99Silver6.0
20
Jul 22, 2006 08:29 PM
1SlowHoe
Oct 12, 2005 06:42 PM
SmokinLM7
Apr 5, 2005 12:29 AM
FILE
Jul 12, 2004 05:11 PM
