help wiring up ls1 fans
Old Jul 12, 2004 | 01:38 PM
FILE's Avatar
Default help wiring up ls1 fans
We just started wiring up some ls1 fans using the pcm to control them. I was under the impression it was pin 42(blue wire) which provide the ground signal to turn on fans. However, on this 2000 siverado pin 42 is not a blue wire. It's a brown wire. Moreover, on my 02 Sierra, pin 42 is a blue wire. Anybody, seen this before. BTW, ls1 fans are going to be controlled using ls1 edit.
Old Jul 12, 2004 | 02:04 PM
mudz5.3's Avatar
Found this for you tib, http://www.ls1truck.com/howto/pcmfan...ng_frames.html
They are referring to the blue connector, pin 42, not necessarily a blue wire. I'll keep looking.
Old Jul 12, 2004 | 02:10 PM
MacADaYear's Avatar
When we did Chingons efan setup he used the PCM control too but he had to add the wire, not tap into one already there
Old Jul 12, 2004 | 02:18 PM
mudz5.3's Avatar
Mac, I was just reading your post in the search section, lol. I was thinking I haven't seen you on here in a while but anyway I just may not be looking or something. That does make sense too tib. If there isn't a wire to tap into, which is probably the case since its a truck pcm, then you would have to get the terminal for the pcm connector and insert it into the pin 42 spot on the blue connector.
Old Jul 12, 2004 | 02:20 PM
FILE's Avatar
Ok.. looks like have it figuired out.... Thanks guys..
Old Jul 12, 2004 | 02:23 PM
mudz5.3's Avatar
No prob bob, i mean tib. Thats what were here for.
Old Jul 12, 2004 | 02:35 PM
MacADaYear's Avatar
I just got back from a month in Cancun
Old Jul 12, 2004 | 03:06 PM
mudz5.3's Avatar
Must be nice!!!! Even if it was job related, jesus that would be cool. Well welcome back, I think!? lol
Old Jul 12, 2004 | 03:27 PM
Sport Side's Avatar
you best post up in the lounge and tell us bout you and the hunnies
Old Jul 12, 2004 | 05:11 PM
MacADaYear's Avatar
Ive been workin on it... my image hosting place is all screwed but.. but its coming
Porscharu914
14
Jan 20, 2016 10:45 AM
kalikid06
Sep 13, 2015 05:48 PM
97gmc
22
Sep 8, 2015 10:56 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
