Will stock pushrods be OK temporarily ??
Old Jan 27, 2005 | 05:58 PM
  #21
Mr. Sandog's Avatar
Hmm, alrighty then. Guess I heard wrong....BTW, the info I got about 7.36" was from Comp....
Most importantly, it seems the consensus is that Yelo is good to go with his stockers should he decides to go that way. Which is good news.
Old Jan 28, 2005 | 01:28 AM
  #22
Yelo's Avatar
Yeah....very good new at this point, The dealer has my head-bolts waiting for me to pick up tomorrow morning (it took them longer than I thought to get them...over a week, they're usually good for getting parts overnight), with that purchase I have everything I need to do the swap
Here's the list....anything seem to be missing ??
Heads (LS2 springs)
Cam
Head Bolts
Head Gaskets
Exhaust Manifold Bolts (I've got 4 broken ones)
Exhaust Manifold Gaskets
Water Pump Gaskets
Front Cover Gasket
Crank Seal
Crank bolt
RTV Silicone, Lock-tite, etc......
Old Jan 28, 2005 | 09:15 AM
  #23
BigKID's Avatar
I assume you are goingto try and reuse you intake and vlave cover gaskets?? Those are the only ones I see missing in you list.
Old Jan 28, 2005 | 09:52 AM
  #24
moregrip's Avatar
what a rush!
Heads (LS2 springs)
Cam
Head Bolts
Head Gaskets
Water Pump Gaskets
Front Cover Gasket
Crank Seal
Crank bolt
when are you planning on doing this?
Old Jan 28, 2005 | 10:28 AM
  #25
Yelo's Avatar
BigKID...actually the valve-cover gaskets are new, but they are already on the new red valve-covers that i am going to use so I really didn't count them, and I HAD though about swapping to new intake gaskets but everyone here has assured me that the old ones will work (and if they are too bad I've got 2 truck intakes and another LS1 intake sitting around with gaskets in them that I can use)
grippy....Next Friday...I HOPE
Old May 15, 2005 | 03:09 AM
  #26
marc_w---what where the differences between the cam you have now and the TR220, lope, power, driveability, etc.? Thanks
Old May 15, 2005 | 07:45 AM
  #27
Fogle07's Avatar
i got a comp xr265hr with stock pushrods and stock springs. havent blew it up yet. turn it 6200 almost everyday of the week
Old May 15, 2005 | 11:32 AM
  #28
litreddevil's Avatar
Banned
I just opened my new Comp pushrods from Summit Racing and 6 of them are BENT (have I told you all about my recent Summit Racing nightmares.....I'll have to sometime, let's just say that it'll be a cold day in hell before I order from them again)....bent to the point that it is plainly visible to the naked eye, you roll them on glass and they wobble like crazy, since the cam is only a 210º/218º .531/.531 lift and the truck will never see more that 6000rpm's do you think the stock pushrods will live for awhile until I can get these replaced with a hardened set ??
I realize that stock pushrods aren't the best even with stock cams but the RPM's won't even be what some stock motors see...and since it's pretty impossible to miss a shift with an auto I won't run the chance of over-revving the motor.....
WELL MINE SEES 7400 AT LEST ONCE A WEEK GET SOME FORM THUNDER RACING ASK FOR DAVIE 225 754 7223 YOU CAN ALSO SHIFT IT ALITTLE HIGHER 6400 IS WERE WE SHIFT THAT CAM
5.3Okasai
Mar 9, 2022 01:07 PM
greedygenius
Sep 3, 2015 06:51 AM
lxcoupe
Jul 30, 2015 02:42 PM
GM1697
Jul 14, 2015 01:21 PM
GRRR65GTO
Jul 10, 2015 08:27 PM
