Will a 6.0 4l80 swap run on a 4.8 tune
Old Oct 31, 2015 | 10:09 AM
Merctech2's Avatar
Default Will a 6.0 4l80 swap run on a 4.8 tune
I'm just about to start the swap and was wondering if I can start the motor to get all fluids full and everything doubled checked before I tow it to the tuner.
Old Oct 31, 2015 | 11:37 AM
Wolftrk99's Avatar
Started my built 6.0 on my 5.3 tune..... Just dont do anything stupid with it, just let it idle and make sure everythings good, would not recommend driving it more than maybe onto a trailer though
Old Oct 31, 2015 | 11:38 AM
Wolftrk99's Avatar
And not for very long....
Old Oct 31, 2015 | 11:39 AM
FFDP's Avatar
It should be alright to just let it warm up and idle.
Old Oct 31, 2015 | 11:40 AM
Merctech2's Avatar
Cool thxs will make me more comfortable knowing all fluids will be full before tuner gets it
Old Oct 31, 2015 | 11:41 AM
Wolftrk99's Avatar
How did you connect the 80.... May not even move if segment swap isnt done... Umless you went with the frost harness over the repin..... Tuner may be able to flash your pcm, to get it so you can drive it there as a base tune or whatever...
Old Oct 31, 2015 | 11:44 AM
Merctech2's Avatar
Yea I havnt so I'm not going to move it at all under power. Just want to get trans fluid full
Old Oct 31, 2015 | 12:05 PM
Wolftrk99's Avatar
I woukd see if your tuner can reflash the pcm with base tune if you bring it to them, save tow bill!! sometimes they will aspart of tuning process... I didnt swap transmissions but truck idled long enough in gear to back it out of garage so tow truck could pick her up.... I was cut short on the space to work on it so i had to have her towed to work to send pcm out for the initial tune and then drove it two hours to tuner.... Was not paying the tow bill for that one much cheaper to fill my boys gas tank to follow me there!!!
Old Oct 31, 2015 | 12:13 PM
Merctech2's Avatar
Yea I'm going to talk to tuner first, hopefully gonna borrow a trailer. All else fails tow truck.
Shtbox
Jan 4, 2016 08:30 PM
Velocity1
Nov 28, 2015 02:52 AM
2000_SS
Oct 31, 2015 02:15 PM
TXjeepTJ
Oct 30, 2015 08:11 PM
Fales
Oct 29, 2015 03:02 PM
