Weepy Washer Fluid Reservoir??
Old Oct 28, 2015 | 10:20 AM
Velocity1's Avatar
Thumbs up Weepy Washer Fluid Reservoir??
When these bottles, rubber and hard plastic lines finally start leaking like my '00 1500, (and it's leaking right at the bottle and perhaps a "fitting" that passes thru into the washer fluid, from what I can tell..
Trying to avoid pulling the new battery out the top if I can fix it from the bottom...
Where do these things typically leak at the bottle, and what's the fix?? Tired of the blue stain.... lol!!
Thanks!
Old Oct 28, 2015 | 11:21 AM
1FastBrick's Avatar
Custm2500's Rude Friend
My self, I haven't seen very many. We don't have extreme weather conditions here.
Usually around the pump. It has a rubber grommet.
Either the pump itself or the gromet. I have seen a few older bottles where the plastic dried out and was cracking. Or they have been damaged by tire's on lifted trucks.
Old Oct 28, 2015 | 11:30 AM
Velocity1's Avatar
Thumbs up
Thanks. The definitive sense of direction I've gotten. Pulling it all out so it can be properly inspected and fixed. Nothing leaks on my truck....., for long..
Thanks!!
Old Oct 28, 2015 | 12:28 PM
someotherguy's Avatar
Had the bottle go bad on a GMT900, since it was a company truck our shop changed out the bottle, and cracked the pump body while cramming it into the new bottle. I ordered a new pump and stuck it in with simply peeling back the wheelwell lining. So I guess what I'm saying is, don't assume it's the bottle unless you can see the damage. Could be the grommet, could be the pump itself as the plastic seems brittle.
Richard
Old Oct 28, 2015 | 08:25 PM
Velocity1's Avatar
Thanks for the additional heads-up.
Old Nov 26, 2015 | 08:59 PM
Velocity1's Avatar
Thumbs up
Interestingly I recv'd a Genuine GM Jug, cap, pump and level sensor from Parts geek. NOS I suspect. The orig. packaging is Fisher/GM nomenclature, pn etc. along with GM logo OEM cardboard header, (circa 99-06). Then it looks like it's remarked by someone before Parts geek got it.
Very ice OEM Nos replacement. May last another 15-16 years.. lol..
Old Nov 28, 2015 | 12:06 AM
1FastBrick's Avatar
Glad you got it fixed!
Old Nov 28, 2015 | 02:52 AM
lxcoupe's Avatar
The black plastic case around my pump motor cracked and started leaking in the middle of the pump. Quite strange. Replaced the pump and fixed it.
Wrecker 426
Oct 28, 2015 11:01 PM
tim wellington
Oct 25, 2015 08:05 PM
chevy02
Oct 23, 2015 01:47 PM
alex1138biancale
Oct 21, 2015 07:41 PM
carid
Oct 2, 2015 09:33 AM
