Will 5.3 Headers work on the LQ9 6.0?
Old Mar 8, 2006 | 06:07 PM
Stawzy32's Avatar
Default Will 5.3 Headers work on the LQ9 6.0?
I want to swap a 5.3 to a 6.0 LQ9 and run either a 408 stroker or a 6.0 and eventually port the heads. I currently have dynatech supermaxx LT's on my stock 5.3 aluminum head. Will there be any problem in using the same LT's with either the 6.0 or 408, ported or not ported? If there is a problem with fit or port alignment, maybe a possible fabrication? Those LT's were kinda pricey to just dump with a swap. I contacted dynatech and they said the headers should bolt on to the heads but the ports are different. Has anyone tried a swap and used the same LT's? Any help would be great. Thanks.
Old Mar 8, 2006 | 06:27 PM
virgils4.85spd's Avatar
Default Yes
I had wondered the same. I found out that everything from a 5.3 will bolt back up to a 6.0.
Derek
Old Mar 8, 2006 | 06:40 PM
Stawzy32's Avatar
I heard that too. I think their headers are the same but from the Headers back they may be different, since they list their headers for the 4.8, 5.3, and 6.0 under the same product number but have different whole system product numbers. Anyways, I love the way they sounded when I installed them, especially past like 3500 RPM's. I did break off a head bolt when I removed the stock manifold but hopefully I can get that taken out somehow and get the last bolt in. No noticeable exhaust leak though.
Still wandering if I am going to have any problems with the swap, especially if I port the heads with the 408 stroker. Anyways, here is their webpage:
http://www.secureperformanceorder.co...ore/truck.html
www.dynatechheaders.com
This is what is listed on their website for the part I ordered:
PRODUCT: 115-841310
99-`05 GM Truck 1500, 2500/ SUV (4.8L, 5.3L, 6.0L)
Fits 00 - 03 Chevy/GMC 1500 and 2500
Fits the following SUV applications
Avalanche
Escalade
Suburban
Hummer H2
Tahoe
Yukon and Denali
Here is for the 6.0 system:
PRODUCT: 115-841350
99-`05 GM Truck/ SUV 6.0L Header System w/o Air Injection
Long 1 3/4” Tube Design
Increase HP & Torque
Improve Economy
Direct Bolt-On Fit
Model fits with and without EGR
For ‘00 -‘03 6.0L
Hummer H2 (6.0L)
Silverado SS (6.0L)
Cadillac Escalade (6.0L)
GMC Denali (6.0L)
Old Mar 8, 2006 | 10:41 PM
SnakeOiler's Avatar
You should not have any problems.
Old Mar 9, 2006 | 12:03 AM
treyZ28's Avatar
yup, my 4.8 and LQ9 manifolds have the same casting number IIRC. I'm running 4.8 manifolds
Old Mar 9, 2006 | 07:06 AM
TigerFan187's Avatar
You sure can! Lots of people run that setup!
Old Mar 9, 2006 | 07:43 AM
dewmanshu's Avatar
Moderately Differentiated
I moved my dynatechs from my 5.3 to the 6.0!
Old Mar 9, 2006 | 08:29 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Question on the Dynatecs, are these a direct bolt on where thhe stock tubing is not cut? Think of getting these. THX
Old Mar 9, 2006 | 08:43 AM
dewmanshu's Avatar
yep..direct.
Old Mar 9, 2006 | 09:11 AM
Fogle07's Avatar
yea it will work. 1slow01z71 is running dynatechs on his 418.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
steves86ta
Jul 28, 2015 10:21 AM
06 4.8
Jul 15, 2015 07:17 PM
supersportsteve
Jul 4, 2015 12:02 PM
