Why would STS base kit be making 10psi+ ????
Old Feb 19, 2005 | 12:35 PM
ronn25's Avatar
The problem with more boost in my case when I first install the kit, like TG02Z71 has, is anything over 5psi and your most likely maxing the stock injectors and going lean.
I think its almost a must to get larger injectors, and a shift kit. And an intercooler if you demand max performance.
Also IAT's at just 5 psi are already over 160 degrees.
Side note, I gained 4mph in just the 1/8 mile by installing the small IC under the truck.
Went to the track one sunday, ran 78mph at 7 psi, IAt's over 150. After the IC install, under even slightly hotter conditions, I ran 82mph at 7psi IAT's around 100.
Old Feb 19, 2005 | 01:36 PM
PappyDan's Avatar
Tribe Shaman
i do not know to much about the turbo set up, don't you have a control valve for the amount of boost pressure you want to make, is this set right or could it be bad from the factory?
Old Feb 19, 2005 | 07:38 PM
TG02Z71's Avatar
Kind of feel like I'm floating in a black hole here, anyone else have any ideas??
No one from Nelson or STS has called me back since yesterday afternoon????
WTF! Man I'm starting to lose hope. I spent allot of money on this stuff and I need some support soon!
Old Feb 19, 2005 | 08:11 PM
bud8fan's Avatar
those guys are prolly freaked about this just as you are...allens got my 5# spring at his house..i can have him send it to you if you want...
Old Feb 20, 2005 | 06:55 AM
TG02Z71's Avatar
That would be cool of you man. I need all the help I can get right now. No one is calling me back!! Pm me if you would like to help me out.
Old Feb 20, 2005 | 07:41 AM
Black02Z71's Avatar
Could it be a faulty wastegate?
Old Feb 20, 2005 | 08:13 AM
i know you want help from sts and nelson but it is the weekend so not everyone is around. so you are just gonna have to be patient. is the tranny leaking any fluid?
Old Feb 20, 2005 | 09:34 AM
just out of curiosity, have you checked it with a manual gauge? I have seen slightly higher psi out of the .4 bar spring at times, but never 10psi. Is the spring large or small? The smaller one fits on the center part or raised area of the inside of the wastegate and a larger one would go in the bigger area around the outside. I wouldnt think there is a chance of this, but hell, its worth a shot.
Old Feb 20, 2005 | 10:02 AM
TG02Z71's Avatar
No leakage, ZERO, but my level checks high now when its cold. Its checking above the warm crosshatche marks even though its cold. It was fine before all this slippage or possible slippage started. The only thing I changed was the night before the slipping started. The return line coming from the turbo into the STS return pump was changed. Because of the way the fittings tightened up I could not get the line to point toward the pump which left the line slightly bent, not kinked but not the way I would like it to be for flow reasons. I changed the hose and messed with the fittings to get the new hose into a better flow position. Now the hose goes up over the filter and back down to the return pump. Could making the oil flow up hill for a foot cause all these problems??? I don't think so but I am going to put some hard piping in and keep it low or at the same level as the return pump. We will see what happens I guess. Its snowing like freaking crazy here now so its going to be hard to tell if its slipping or not.
Old Feb 20, 2005 | 10:04 AM
TG02Z71's Avatar
I have no way to check the spring, I am going to remove the wastegate cover carefully and see if there is anything that is noticeibly binding or just not right. I'll take some spring measurements with a caliper and post them soon. Time to go lay on the cold concrete floor again, it 30 degrees out here today. At least I have a garage I guess.
