Why won't edit read?
Old Mar 2, 2004 | 06:23 AM
  #31
GREGGO's Avatar
Originally Posted by Procharged LM7
I have a USB adapter cable, and I had to buy a Keyspan cable to get anythign to work.
Worth a try maybe hooking up a USB setup, since your serial connection isn't working.
Two other cables would not let it connect.
Did that, didn't work. The serial connection does work with a-tap. No matter. I bought a new laptop that only has USB. I bought the adapter, and will give it a shot this week.
Old Mar 2, 2004 | 09:15 AM
  #32
Flyer's Avatar
I think it might be your cable. It could also be something to do with your truck.
I tried ot on mine before I had the new version of edit and it just said no connection. Once I got the newer version it would connect, but I used the benchtop cable and had no problems.
PM me your email addy ..
Old Mar 2, 2004 | 10:01 AM
  #33
Has edit ever worked right for you? Sounds like you have tried nearly everything. You may want to try a benchtop cable if you know someone that has one. Sounds like you have a problem with the cable they sent you. Do the lights come on the cable unit? Do you see them flashing/moving at all?
Old Mar 2, 2004 | 11:48 AM
  #34
GREGGO's Avatar
OK, I pretty much have tried everything:
Several cables
several PC settings
etc.....
Some lights work, some don't.
But as of now, the point is moot. I will be hitting MTI Friday morning at 9:00 and let the experts try again with the new laptop. If it doesn't work this time, I'm selling the truck and getting a Yugo!
NOT!!!!!
Tydriver
45
Oct 23, 2015 09:19 PM
sprayed99
Sep 21, 2015 04:47 PM
FormulaZR
Sep 14, 2015 05:23 PM
akcooper9
Sep 13, 2015 04:50 PM
brandon_6667
Sep 6, 2015 04:49 PM
