Why won't edit read?
Old Feb 27, 2004 | 11:46 PM
  #21
Fast 48,what cam are you running? The only place mine needs tunning is at idle,and I think I,ve about solved that tunning the throttlebody. If I get it running good enough to make Texas I'll get Allen ( the class sponsor) to look at it. But it runs good with hypp tuning....bumped a little.
A flat #'s all ya need to have fun all day.Look forward to seeing you again. Jim
Old Feb 28, 2004 | 12:45 AM
  #22
Flyer's Avatar
Try using the cables from your ATAP cable but the box from EDIT.
If I remember right that Dell has 1 serial port. Do you have a modem installed on it? If you do, that would be your Com2, so Com1 should be your serial port.
I would give the cables from the ATAP cable. If it works after that, try the other ones one at a time and then you will be able to figure out which cable is bad.
Old Feb 28, 2004 | 08:29 AM
  #23
BigTex's Avatar
Do what Flyer said, and use the serial cable from your autotap.
On the same properties of your serial port, under the settings tab, set them like this:
Old Feb 28, 2004 | 07:44 PM
  #24
GREGGO's Avatar
To late...got a new laptop.
BTW, I tried the cable swap lng ago. I'm now facing getting the USB to serial adapter. But at least I got a pretty badass laptop out of it.
HP Pavillion ZE5600
Celeron 2.8GHz
60GB Hard drive
512 MG memory
54g Intergrated wireless LAN (does that mean I can get my DSL wireless with the right router?)
DVD/CD-RW
Windows XP
Will play with it on the truck tomorrow. I'll be selling the other one. BTW, i have this one on dielup right now.Not to shabby.
Old Feb 28, 2004 | 07:46 PM
  #25
GREGGO's Avatar
Uhhh....Is LS1Edit XP compatible? I gotta check that real quick, be right back.
Old Feb 28, 2004 | 08:01 PM
  #26
BigTex's Avatar
I've only used LS1 edit on XP. Well, thats not quite true, but I started using edit on XP. Works fine.
If you already have DSL, you'll really like the wireless connection with the new laptop.
I drive around with a USB wireless adapter sitting on my dash. Its so easy to find open wireless networks. I get a better signal with the USB adapter than the PC card version. When I need to check my email or something, I just veer off towards the nearest neighborhood or apartment complex. Then just find an open wireless connection. FWIW - I've found that almost every car dealership has a wireless AP setup and running. Some are locked and others are wide open.
Old Feb 28, 2004 | 08:30 PM
  #27
XLR8NSS's Avatar
Adkoonerstrator
Hahaha...I use my neighbors wireless connection sometimes. It's a little faster than mine.
Old Feb 29, 2004 | 10:34 AM
  #28
Flyer's Avatar
LOL ... I'm secruing mine now. I was in te hood, no one would have a computer th4ere, but now I'm on a highway.
BT .. I can't get mine to update fast enoguh. By the time it's found a signal I could have already gone passed the hot spot and to the next one.
Old Feb 29, 2004 | 12:04 PM
  #29
BigTex's Avatar
You have to stop to get a good signal. J/K.
Take a look at this bad boy: Network Stumbler
It really comes in handy for anyone troubleshooting a wireless connection (or looking for good signals). It works best in Win XP. On older OSs, it only supports a small list of network cards.
Old Mar 1, 2004 | 08:56 PM
  #30
Procharged LM7's Avatar
I have a USB adapter cable, and I had to buy a Keyspan cable to get anythign to work.
Worth a try maybe hooking up a USB setup, since your serial connection isn't working.
Two other cables would not let it connect.
