Why is my DOD retarded? (Cam timing issue)
Old May 22, 2014 | 08:37 AM
Forcefed86's Avatar
8 Second Club
Default Why is my DOD retarded? (Cam timing issue)
Has anyone degreed in a cam on a DOD crankshaft? Are the keyways in a DOD crankshaft cut to a different position than a standard NON-DOD crankshaft?
Reason I ask is I recently installed a new aftermarket isky cam. Originally just threw the cam in 2* advanced and ran it. Car ran horrible. So I got out the degree wheel and an OEM timing set. Come to find the cam is 6.5*retarded to the cam card “Dot to Dot” with an OEM gear set. (8.5* total!) I thought I had a bad cam so I ordered another. I got the exact same 6.5* retarded reading “Dot to Dot”. With an adjustable timing set I was able to get the cam to degree in .5* Adv from the cam card spec. Put the car back together and it’s a monster. Went from 160-195+ cranking compression. Sounds completely different, revs faster and makes a ton more power.
IMO I’ve pretty much eliminated the timing set’s as I have used 1 older OEM set and one brand new OEM set with the same results. And I’ve eliminated the camshaft error. 1 or 2 degrees may still be in the camshafts, but the majority I believe to be in the crank keyway positioning.
Anyone else degree a cam in on a DOD 5.3? (LC9 I believe, 2008 alum 5.3, no variable timing on this one) If you didn’t and your down on power, you may want to!
Old May 23, 2014 | 08:16 PM
craigsix's Avatar
check the stickey on the gmt900 forum.
Old May 24, 2014 | 02:09 AM
Forcefed86's Avatar
8 Second Club
Which sticky? My setup didn't have VVT. So I don't think that that applies? It was DOD engine only.
thanks!
Old May 27, 2014 | 08:53 PM
craigsix's Avatar
thanks!
oops my bad.
ARC
57
Feb 21, 2022 10:54 AM
OHsixLS3
Dec 27, 2016 09:30 AM
Mr. Chainsaw
Aug 5, 2015 07:54 AM
EscaTruck
Jul 20, 2015 11:42 AM
GMCtrk
Jul 17, 2015 06:39 PM
