LS2 Cam into a 5.3?
Old May 23, 2014 | 12:55 PM
Default LS2 Cam into a 5.3?
Is a stock LS2 cam useable in a 5.3 liter truck motor? And if so will it make any power difference at all? May be a dumb question lol
Old May 23, 2014 | 01:03 PM
TXsilverado's Avatar
if you decide to do it, i have a single bolt LS2 cam laying around.
Old May 23, 2014 | 01:29 PM
gamble686's Avatar
The difference will be minimal maybe 20hp all of which will be gained above 4000rpm. Not worth the hassle. It's almost the same as a LS6 cam.
Old May 23, 2014 | 01:58 PM
20hp for $100 sounds like an amazing deal to me lol. i've spent a lot more for less power.
Old May 23, 2014 | 02:16 PM
Yeah i figured it would be minimal. Its the old cam out of my 05 gto lol. Was wondering if i could put it to any use. Was worth a shot
Old May 23, 2014 | 03:46 PM
grey matter 04's Avatar
13 Second Truck Club
Basically that's the same as the early z06 cam
Cheap and easy way to gain 30hp with no loss of lowend.
Good for a budget cam swap !
Old May 23, 2014 | 04:17 PM
Would there be any other necessary changes to be made or is that a cam i can just throw right in there with stock springs, rockers, etc?
Old May 23, 2014 | 10:39 PM
gamble686's Avatar
Come on you have done enough cam swaps to know the gaskets, bolts, guilds etc will cost a lot more than that to get it done.
You will need yellow springs at minimum. Hardened pushrods are a good idea while you're in there since the stock ones aren't so strong when spinning that motor up. It can snowball from there.
Old May 25, 2014 | 09:28 PM
}BlueFire{'s Avatar
https://ls1tech.com/forums/showthread.php?t=1644213&styleid=27
Old May 25, 2014 | 09:30 PM
brewster240's Avatar
if you have a gen 3 engine, you will need timing gear, timing cover, cam sensor, and lengthen the cam sensor harness from rear to front
