Why do Duramax trucks only come with 3.73:1s?
Old Jun 16, 2003 | 03:34 PM
Hit Man X's Avatar
Default Why do Duramax trucks only come with 3.73:1s?
Well why do they? Is it due to the turbo needing something to push against with all the boost?
Thanks!
Old Jun 16, 2003 | 03:41 PM
1BADHD's Avatar
Default Re: Why do Duramax trucks only come with 3.73:1s?
You dont need a low ratio due to all the torque available and low first gear in the Ally. But if you want to, gears are now ready to install for the 11.5 rear. Took them over a year to make them, but, better late than never. Up to 4.56's. Can you imagine the low end with 4.56 rear and the torque of the D-max? WOW!!!!
Old Jun 16, 2003 | 04:14 PM
Hit Man X's Avatar
Well I figure if I tossed on some larger tires instead of those tiny weight rated ones, I would hurt the fuel economy as well as performance...sorta like what happened to your truck BADHD. Speaking of which have you tried running down the freeway at 60MPH in D? That may help out your fuel economy until you decide on gears/converter.
The stock tire height is ~30.5" and I would probably go to around a 33" tire so the truck looks normal. That would put me needing about a 4.10:1 gear set, BUT I really would like to go to a 4.30:1 gear set but it seems no one makes that low of a gear.
Here is what I came up with...
3.73:1 + 30.5" tires @ 70mph = ~2025rpms
3.73:1 + 33" tires @ 70mph = ~1850rpms
4.10:1 + 33" tires @ 70mph = ~2050rpms
4.30:1 + 33" tires @ 70mph = ~2150rpms
4.56:1 + 35" tires @ 70mph = ~2150rpms
Can 35" tires be on a stock ride height? Is an Eaton Posi avaiable for that gigantic 11.5"?
Old Jun 16, 2003 | 04:50 PM
Neil 6.0's Avatar
From: as far away from Koonerville as humanly possible
They only offer 3.73's because GM is afraid they would lose Kodiak/Topkick sales if 4.10 or 4.56 gears were available.
Old Jun 16, 2003 | 07:19 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I have 33s on my Dmax and have 0 problems with bottom end torque.I would'nt even consider a swap unless going bigger than 35s.You cant compare a 6.0 to the torque of a Dmax.A gear deeper than a 3.73 is unnecessary with an Ally Dmax combo.I've pulled 23,000 lbs with my truck no problems whatsoever with acceleration.A 4.10-4.56 would be more gear than the brakes and suspension could ever stop or hold(towing wise).See sig for performance in the 1320 with 33s spinning half way down the track.
Old Jun 17, 2003 | 11:18 PM
Hit Man X's Avatar
Yeah, but did your fuel economy decrease with the larger tires?
Old Jun 18, 2003 | 09:48 PM
10.5 Dave's Avatar
7 Second Club
Yes fuel economy did drop about 1-1.5 mpg.IMHO if someone didnt like the very small decrease in performance JUICE IT.Upping the power is alot cheaper and more fun than a gear swap,especially with a 4x4.The small decrease in economy is well worth it for the look,those little donuts Chevy puts on these trucks look goofy.
Old Jun 19, 2003 | 01:21 PM
Hit Man X's Avatar
Well yeah, but seeing as how I would stick an Eaton E-Locker up front and a REAL limited slip out back, a few $100's more for the gears wouldn't be too bad.
Oh yeah, those 245/75R16 are weight rated hence them being on those trucks. I'd never tow anything that would need that sort of tire so, I would off them too. Probably a 305/70R16 or something comparable.
wrb002
Aug 31, 2015 12:00 PM
Suburban2500
Jul 19, 2015 04:50 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
black6spdz
Jul 16, 2015 01:32 AM
Nimoryan
Jul 5, 2015 03:50 PM
