Who here has done the LS1/LS6 intake manifold swap?
Old Apr 29, 2004 | 06:17 PM
  #21
boonybouncer's Avatar
I want to do the same swap with the 90mm LSX intake. Can someone post some pics, and simple install instructions. Thanks.
Old Apr 29, 2004 | 06:20 PM
  #22
2003blue5.7's Avatar
Originally Posted by Yelo
I'm not so sure why people have such a hard time with this swap.....it took me about hour and a half to complete from start to finish
1. you CAN use the truck rails and injectors......all that is requires is spacers/bushings and longer bolts, the truck crossover looks stupid but works.....custom bent one like I did if you are worried about it
2. the truck water-pump works JUST FINE, cutting the water neck off about 3/4" above the pump and adding a 45* adapter and a short piece of hose was all I needed to make it work
3. EVERYTHING ELSE is a DIRECT SWAP
you should mention the tenision pully too. I know that will be in the way.
byrne_06
Apr 29, 2017 02:19 PM
OHsixLS3
Dec 27, 2016 09:30 AM
USMCvet0311
Sep 30, 2015 10:34 AM
Hmguyton
Jul 7, 2015 03:29 PM
Black-Syde
Jul 6, 2015 02:12 PM
