Who here has done the LS1/LS6 intake manifold swap?
#22
Originally Posted by Yelo
I'm not so sure why people have such a hard time with this swap.....it took me about hour and a half to complete from start to finish
1. you CAN use the truck rails and injectors......all that is requires is spacers/bushings and longer bolts, the truck crossover looks stupid but works.....custom bent one like I did if you are worried about it
2. the truck water-pump works JUST FINE, cutting the water neck off about 3/4" above the pump and adding a 45* adapter and a short piece of hose was all I needed to make it work
3. EVERYTHING ELSE is a DIRECT SWAP
you should mention the tenision pully too. I know that will be in the way.
