Who did it..........
Old Sep 12, 2007 | 10:45 AM
Mark Johnson's Avatar
Default Who did it..........
Alot of folks have done alot of different stuff with their trucks, ie; 4.8 to a 6.0, hogg out a 5.3 to 5.7, straight LS1 drop in, while many opt going right up to the 6.0. I'm after the last mod, the 6.0; as many folks that have done it, I'm kinda hesitant as owners of the HD trucks are less than enchanted with gas mileage. But swapping said 6.0 beast into a half ton truck, what were any effects on gas mileage.
Figured instead of going the trouble to punch out the 5.3 to 6.0 I can get a 6.0 iron block from Scoggin for around $600, and an aluminum one for another $300 after that...........
Old Sep 12, 2007 | 10:54 AM
nonnieselman's Avatar
The HDs also have a 4L80 and weigh a little more than your truck.. and most of them have 3.73s and 4.10s... im goin to guess yours has 3.73 being a 4wd? or 3.42s..
It depends on alot of things...
Old Sep 12, 2007 | 11:09 AM
Yeah- I have 3.73's. Was also wondering how much the 4L80 eats up, I'm planning to stick and FLT 4L6x behind it. Be kinda nice to have a little more punch up here at 7,000ft, any recommendations or comments on the Crane Gold rockers.................
Old Sep 12, 2007 | 12:24 PM
mwalls54's Avatar
Need More N2O Mod
your gas milage isn't going to really change that much. well other than you will want to floor it alot more.
Old Sep 12, 2007 | 01:01 PM
That's what I'm thinkin', what with the weight of the truck remianing the same, but I still wonder why the 3/4 ton trucks suffer on mileage so bad, is it their extra weight, the 4L80 and I won't even mention 4.10 gears..........
Old Sep 12, 2007 | 01:13 PM
RandomHero's Avatar
also factor in that 2500hd trucks weight 7000+ pounds. That's about 1500 lbs. more than your truck. The problem with the 4l80e isn't so much the parsitic drivetrain loss but the o/d ratio(.75 I believe instead of .70) is going to make you turn more rpms at highway speeds.
Old Sep 12, 2007 | 01:20 PM
Blaze5509's Avatar
Are you saying that because he is an AWD extended cab or just comparing engines.
I was under the impression that the 6.0L got about 12-14 in the city and 15-17 on the highway.
My RCSB with 3.73's gets about 15-16 in the city and 18-21 on the highway
Old Sep 12, 2007 | 01:47 PM
RandomHero's Avatar
Again, like I just said that's in a 7000 pound truck
Old Sep 12, 2007 | 02:23 PM
It;s not AWD- I just stuck the C3 monniker on there. The truck is a 5.3 with manual/ stick part time 4wd. In the grand scheme of things, I have made it from here, Santa Fe NM, to Sayre OK on a tank of gas with a 400lb ATV in the back..........
Old Sep 12, 2007 | 04:03 PM
SS_bnoon_SS's Avatar
I can pull 17 or so interstate MPG with my 6.0, but that's full time AWD, auto, 410's, and short 275/45/20's. When I had my 275/55/20's I could pull 19-20 interstate, and that was before any real mods other than a tune.
