Who did it..........
Old Sep 12, 2007 | 06:14 PM
nightrunner's Avatar
Mr. Obvious
couple of things worng with the first post, 1. you cant bore the 5.3 to a 6.0, 5.7 is the max bore wise. 2. the aluminum aluminum 6.0 would have to be the ls2 block and its a gen4 block and there are a few things that are different about those.
Old Sep 12, 2007 | 08:42 PM
knuckles's Avatar
yea you can if you stroke it my 5.3 is going to be 405 cid
Old Sep 12, 2007 | 08:44 PM
Mr. Obvious
notice i said bore wise
Old Sep 14, 2007 | 08:38 AM
Mark Johnson's Avatar
THis is getting to be a bigger can or worms than it's worth. I'm just gonna punch out the block to 5.7 and run with that.........
Old Sep 14, 2007 | 08:45 AM
RandomHero's Avatar
No it's actually pretty easy. It's just the examples you listed are not worth it.
Buy a lq4 or lq9 out of a truck or SUV that came with it from the factory. If you find a good deal you could spend as little as $800 or so. After that the engines are a direct swap with the only real issue being that you need a new tune.
Old Sep 14, 2007 | 09:27 AM
Yeah, that lq4/ lq9 route sounds more prudent........
Old Sep 14, 2007 | 09:49 AM
Tootall's Avatar
you don't even have to swap the entire engine over . . . all you need is a long block. Everything else swaps over.
Old Sep 14, 2007 | 10:28 AM
Y'know- what I'm really yearning for is that classice low end snap as affoded by the iron- headed LT-1 from the '96 Impala SS.............
Old Sep 14, 2007 | 02:44 PM
SS_bnoon_SS's Avatar
Pshhhhhh, childs play for a 6.0 with the right cam.
Old Sep 14, 2007 | 03:07 PM
6.0 it is, then. Guss I'll keep my eyes peeled around the area, thanks. BTW, what cam will provide that off- the line, wtoplight to stoplight snap..................
