Whipple and TEC
Old Nov 8, 2003 | 11:01 AM
jdpanero's Avatar
Default Whipple and TEC
Has anyone run Top Engine Cleaner through their Whipple? I'm not exactly sure if the compression of a liquid with the clearances of those screws would be a good idea.
Old Nov 8, 2003 | 11:05 AM
parish8's Avatar
single digit dreamer
i dont know anything about TEC but was always under the impresion that you dumped it into the spark plug holes.
if there are deposits insede the whipple i would just leave them there, there not hurting anything.
Old Nov 8, 2003 | 11:10 AM
jdpanero's Avatar
Sorry Parish, let me clarify. I meant, run the TEC through the TB and Compressor on its way to the manifold and valvetrain. Is this a bad idea? Someone on the Pacific Audio forum wouldn't do it last year b/c they were worried about the compressor grenading.
Old Nov 8, 2003 | 11:17 AM
parish8's Avatar
what is the normal way to use TEC? if you normaly run it thru the TB and into the motor then i wouldn't be afraid to run it thru the blower too.
Old Nov 8, 2003 | 11:35 AM
jdpanero's Avatar
You are supposed to spray or pour it into the TB.
Parish, after LMAO watching you kill those punks w/your 6.0, I see you are a wizard with forced induction . But wasn't that also you who had the fireball shoot out the front of your new rig
I still don't know what to do.
Old Nov 8, 2003 | 12:19 PM
BigTex's Avatar
I uses TEC on my whipple'd truck last year. I sprayed into the whipples aux injector rail (but I had the injecctors and computer removed).
Others have sprayed it into other holes in the intake (like the PCV inlet on top). I'd prefer to spray it closer to the filter so it has time to mix and give it equal distribution.
I think you could spray though the compressor. Couldn't be any worse than guys spraying nitrous through it.
Old Nov 8, 2003 | 07:24 PM
Ryan23silverado's Avatar
should be fine man. on twin screw sc the rotors do not touch and there is no teflon to seal air between the rotors. i.e. nothing the tec would chemically breakdown in the sc.
Lthompson
Oct 2, 2015 12:45 AM
lxcoupe
Sep 22, 2015 02:50 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
MS3Z
Jul 30, 2015 06:17 PM
