whipple problem
Old Nov 24, 2004 | 04:52 PM
Default whipple problem
I have 2003 hd whith a whipple and a whipple tune. It keeps throwing p0101 codes , cant figure it out. Can anyone help
Old Nov 24, 2004 | 04:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
That is a MAF code.
Old Nov 24, 2004 | 05:01 PM
Originally Posted by BlownChevy
That is a MAF code.
had dealership ceck everything checks out ok including maf
Old Nov 24, 2004 | 08:43 PM
speedy02's Avatar
P0101 is Maximum delta airflow.It's a MAF code.Your exceeding the threshold value of that table..
Old Nov 24, 2004 | 10:01 PM
i used to get that code all the time. it drove me f'n crazy. somehow allan got rid of it with edit. not sure how, sorry
Old Nov 25, 2004 | 12:17 AM
TireFryerSS's Avatar
My truck has been throwing that code evar since I've owned it...never had one problem.
Old Nov 25, 2004 | 12:18 AM
Ryan23silverado's Avatar
If you are maxing the maf, be aware of your fueling. You will go lean very quickly once you max it (unless you are tuned for it) because the fueling numbers will not be in normal relation to the maf at the rpms where you hit the mafs limit anymore.
If you have edit, see at what rpm you max the maf out at and add fuel from that rpm cell and higher in the PE versus rpm table under fueling.
Old Nov 25, 2004 | 05:04 AM
sfj
running too lean would not be a good thing lean is mean until it breaks then it will not be a good day
Old Nov 25, 2004 | 07:54 PM
what i cant figure out is why i can run a wot all day and it wont throw any code. At part throtle is the only time it throws that code
Old Nov 25, 2004 | 07:58 PM
I think it is an 'out of boundary' code. I fit seems a lot more airflow at the rpm than it is programmed to see, it will trip this. You may just be flowing more air at say 1600-1800rpm than it thinks it should be seeing. It will then set the code.
You can fix this boundary limit in edit.
