Whipple install gone bad
Old Oct 27, 2004 | 12:51 AM
  #21
OUT2WIN's Avatar
Its dripping oil out the side of the block so definetly its the gasket. The spark plug that would be wet would have to be the one closest to the leak right?
Old Oct 27, 2004 | 12:52 AM
  #22
Stroker 1500's Avatar
Originally Posted by I8AHEMI
The smoke was white like paper. The temp seemed to be normal but maybe the thermostat stuck. This **** sucks. Tomorrow the tear down begins.
AHH..well then it's definately the head gasket.. get that bish replaced and give it hell ... be sure to do a visual inspection well everything is off though just for safe measure
Old Oct 27, 2004 | 12:55 AM
  #23
Old Oct 27, 2004 | 12:56 AM
  #24
OUT2WIN's Avatar
I hope you are right rcfast! A blown head gasket is better than a blown motor!
Old Oct 27, 2004 | 12:57 AM
  #25
Worm's Avatar
If that engine isn't blown its the messiah of the 5.3 Liters. Pull the heads and check, don't ask us
Old Oct 27, 2004 | 01:03 AM
  #26
OUT2WIN's Avatar
Old Oct 27, 2004 | 01:09 AM
  #27
On another note. Be sure to get that head off and all the water out asap so it doesn't do any damage, and try getting it back running as soon as you can. Also should be a given but change the oil and flush the cooling system after you get it back together. And once you get it running don't romp on it until you figure out what was causing the detonation otherwise you will be in the exact same situation or worse almost instantly.
Old Oct 27, 2004 | 01:15 AM
  #28
OUT2WIN's Avatar
What would cause detonation? He's got the TR6s. Maybe a tune should be next. What if there is no water mixed in there? If its just the gasket, it should be up and running soon.
Old Oct 27, 2004 | 01:17 AM
  #29
James B.'s Avatar
Try using some high quality gaskets. The Gen-III blocks have fewer bolts holding down the heads than the old SBC. I'm not sure if Cometic makes gaskets for it yet - they make a great multi-layer steel gasket with good sealing strength. That's what a forced-induction motor needs. I run Cometic head gaskets on mine too.
Old Oct 27, 2004 | 01:20 AM
  #30
OUT2WIN's Avatar
Thanx for all the info guys! I will post up the teardown tomorrow. My cousin was gonna start taking it apart already. Damn a blown motor on a 01 with 55k miles really sucks.
