Where do lifters go ?
Old Nov 23, 2004 | 01:19 PM
redaddiction's Avatar
Default Where do lifters go ?
When they fall sliding in my cam and the last sob decided to fall on me. Don't they fall into the oilpan ? If so can I just leave it there and throw another one in there ? I'ts just not my day
Old Nov 23, 2004 | 01:24 PM
BigKID's Avatar
Yes it falls into the oil pan and No, I would not recomend leaving it in and just throwing another one in there.
Old Nov 23, 2004 | 01:28 PM
And i bet it's not possible to pull the pan out without pulling the motor is it
Old Nov 23, 2004 | 01:35 PM
BigKID's Avatar
Yes, you can drop the pan without having to pull the motor.
Old Nov 23, 2004 | 01:37 PM
L-EATER's Avatar
11 Second Truck Club
If they went all the way to the bottom of the pan, I wouldnt worry too much, but theses motors have a windage tray which most likely caught 'em. Yes, the pan will come off a 2wd reg cab with the motor in, not sure about other body styles. Your luck sux as bad as mine.
Old Nov 23, 2004 | 01:41 PM
Youre telling me about bad luck I have been waiting on parts and other goodies from a local shop that took a month. I got sick of waitng for my custom grind cam and just bought a used one. I have another shop that I've been waiting on some nitrous parts for well over 8 months . I guess I can try to get the lifter out now I get to pull the head off and all that good stuff. It's going to be a long night I hope it works out.
Old Nov 23, 2004 | 02:16 PM
I did that once
I bought a long magnet and fished the lifter out from the pan.
Worked for me
Beats removing the oil pan
Old Nov 23, 2004 | 04:23 PM
OBXMarine's Avatar
Maybe try changing the oil? You'll be surprised what may come out:
https://ls1tech.com/forums/showthrea...hlight=Oil+Pan
Old Nov 23, 2004 | 08:22 PM
Well the lifter is on the windage tray so it will be necessary to drop the sob the cam is in at least I should have it back together tonight if I work long enoguh
Old Nov 23, 2004 | 09:43 PM
jlwz71's Avatar
Been there done that. I had to remove the front axle to get my oil pan off.
