When to swap out lifters?
Old Aug 9, 2003 | 10:48 PM
IslandTahoe's Avatar
Default When to swap out lifters?
When would we need to swap out lifters?
Mileage? Cam Swap?
What are the benefits of the Pro Magnum Hydraulic Roller Lifters "Comp R"?
Any others options for lifters?
Thanks
Old Aug 10, 2003 | 01:08 AM
Default Re: When to swap out lifters?
I doubt you'll see enough if any difference in performance by changing just lifters to justify the cost.I've never heard of any durability with the stock lifters.I would'nt even consider adding them unless I allready had the motor torn down.
Old Aug 10, 2003 | 02:11 AM
Thats the point, I got a spare motor in the garage and want to do everything now. I haven't heard about any lifter issues, but I haven't heard if they wear. The stock lifters are fresh, about 1K miles but I was also wondering if the aftermarket units offered any improvement.
I would guess not. Good.
Old Aug 10, 2003 | 05:10 PM
Flyer's Avatar
If you stick a cam in .. I would do lifters then. I would go with a roller hydraulic lifter for sure.
Are the lifters in our trucks already roller or flat tappet style?
Old Aug 10, 2003 | 05:47 PM
Our trucks come with hydraulic roller lifters.If I were building a new motor I would consider running the Compcams lifters and rockerarms with one of their cams.Be sure to check their installation specs I think the Compcam lifters use a different preload than stock.Are you building a 6.0 block or what?
Old Aug 10, 2003 | 06:15 PM
Banned
the comp cams lifters are a SAME AS STOCK replacment....they just offer "better" quaility and maybe a better material. i'll use'em in my 370 only because i don't want to take any chances while spinning to 6800+
Old Aug 11, 2003 | 12:27 AM
I'm puuting together an LQ9. Trying to get 10.5:1 CR, a 112LSA cam, P&P heads. I want to try and do all of the upgrading now while I have the motor on a stand.
Old Aug 11, 2003 | 01:51 PM
Hit Man X's Avatar
Well ya if you are doing a full build get some new roller lifters, they are cheap insurance.
Old Aug 14, 2003 | 07:23 PM
What's the difference between the comp stock replacement lifters and the "Comp R" lifters.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
superchomper2003
Aug 26, 2015 09:39 AM
Denali08
Aug 9, 2015 04:34 PM
lxcoupe
Jul 30, 2015 02:42 PM
Suburban2500
Jul 19, 2015 04:50 PM
