When does the stock air box become a restriction?
Old 06-03-2016, 07:46 PM
Gbrown1320's Avatar
Default When does the stock air box become a restriction?
I've got a 99 Silverado that has been swapped with a 6.0L LQ4 with a 228R cam and supporting bolt ons. I'm getting ready to swap on a TBSS intake and 90mm throttle body and currently have an Airaid MIT tube with a K&N in the stock air box. At what point does the stock air box become a restriction on these engines? Has any body done any testing or have any before and after input for a higher HP situation through the stock box?
Old 06-03-2016, 08:10 PM
FFDP's Avatar
I have nothing for real data but all you have to do it cut the stock box open more.
Make the whole side open and drill a hole or two in the front and it will have all the air flow it needs.
Old 06-03-2016, 11:23 PM
0235SS93's Avatar
I've read the stock airborne can support 700ish. Having said that, I have made around 630 crank hp with a stock airborne and drop in filter
Old 06-04-2016, 10:53 AM
Custm2500's Rude Friend
1FastBrick's Avatar
This comparison was done on another site back in the day. Cai Dyno Wars Results - Bolt On Performance - SilveradoSS.com
From top to bottom on the horsepower curve on the graph is:
AEM no filter
KNN
AEM
Stock with KNN drop in filter
Outlaw
GMPP
Stock with Fram airhog
Old 06-04-2016, 11:03 AM
1FastBrick's Avatar
Also Found this one done by justin of Black Bear Performance.
Old 06-04-2016, 02:49 PM
Gbrown1320's Avatar
I've read those data sets before and understand that the stock air box performs well with the addition of an airaid MIT and K&N. Which is why I have run the exact combination up to now. However, all of that testing has been done on relative stock trucks with smaller displacement engines. And that is what has me wondering when that combination begins to loose efficiency and become a bottle neck. I suppose that I can measure my KPa once the new intake and TB are installed, that would be the definitive tell all for my particular application.
Old 06-08-2016, 12:04 PM
Registered User
yetavon's Avatar
My 05 Silverado came with a K&N, and I just added the Airaid MIT. Noted that the TC stays locked further up the hills around here, slightly peppier feeling taking off. But it also gets LOUD easing past about half throttle and feels flat....HPtuner showing knock retard kicking in.
Old 06-09-2016, 10:42 PM
The perceived power difference most feel and swear by from changing out the stock box to aftermarket CAI is just the effect of leaning out the factory tune.
Stock boxes flow very well for the most part any gains to be found are in the box to throttle body duct.
02Sierra2500hd
03-23-2016 10:30 AM
opsguy34
03-17-2016 05:14 AM
stroker87
03-13-2016 06:12 PM
turbo39402
03-07-2016 09:35 AM
05RST2NV
03-06-2016 10:45 PM
Quick Reply: When does the stock air box become a restriction?
