Whats next?
Old Feb 18, 2007 | 09:46 PM
  #51
bigbadwolf54's Avatar
13 Second Truck Club
hmm might explain the shift point problem, with a 29.7in tire and 4.10s 6000rpm should be about 42mph, 35mph is about 5000rpm
Old Feb 18, 2007 | 09:49 PM
  #52
Phantom's Avatar
11 Second Club
my tires are 31.22...
Old Feb 18, 2007 | 09:51 PM
  #53
ok that puts 6000rpm at 44mph roughly..think ya'll just need to get out and tune those shift points...should help ya out
http://www.f-body.org/gears
Old Feb 19, 2007 | 09:05 AM
  #54
if you start pulling timing at 5300rpms, what rpm was your peak hp? Sounds like maybe you got a spot on driving tune, but not a good WOT tune. Your highest timing should be at your highest rpm. With that cam you shouldnt hit peak hp till around 6300rpms.
Get out on the road and tune that thing at WOT. You should have noticed a big difference going from 3.23 to 4.10.
Old Feb 19, 2007 | 09:48 AM
  #55
dirt track racer 81's Avatar
his timing drops off one degree at 5500 rpm..ive been trying to figure that out and i think i may have it..he only makes power till about 5300-5400..ive been playing with his tune and his date log and looking at his dyno sheet the last 10 minutes
Old Feb 19, 2007 | 09:50 AM
  #56
Originally Posted by DozerDan
the only retune we did was for the speedometer...
danny it adjusts the shift points also.we'll take it out tomarrow and play with it
Old Feb 19, 2007 | 10:57 AM
  #57
Tootall's Avatar
why the blower cam? does it really help that much?
Old Feb 19, 2007 | 12:36 PM
  #58
onebadrubi's Avatar
what you mean why the blower cam? That cam isnt exactly a all out blower cam. It should make good power all throughout the power range and be a nice cam in a 5000lb plus truck. It should start to pull about 2800 and pull well past 5500. If the manifold isnt restricting.
Is the cam advanced +4 upon install? It most likely has +4 grounded in it.
Old Feb 19, 2007 | 01:05 PM
  #59
Tootall's Avatar
I remember seeing somewhere that the cam came out of a 6.0, or 5.3 with a blower. He liked the way that it sounded.
Old Feb 19, 2007 | 01:13 PM
  #60
If it was advanced 4* on install and has 4* ground in it would be killer off idle and peak very low in the rpms. And it would have a lower max power than a strait up install. Could be.
What is the timing at WOT? It should be running at least 28*, if not 30*. I'm running 33* and it has ***** at all rpm. Top end it never stops pulling.
