Whats next?
#53
ok that puts 6000rpm at 44mph roughly..think ya'll just need to get out and tune those shift points...should help ya out
http://www.f-body.org/gears
#54
if you start pulling timing at 5300rpms, what rpm was your peak hp? Sounds like maybe you got a spot on driving tune, but not a good WOT tune. Your highest timing should be at your highest rpm. With that cam you shouldnt hit peak hp till around 6300rpms.
Get out on the road and tune that thing at WOT. You should have noticed a big difference going from 3.23 to 4.10.
#55
his timing drops off one degree at 5500 rpm..ive been trying to figure that out and i think i may have it..he only makes power till about 5300-5400..ive been playing with his tune and his date log and looking at his dyno sheet the last 10 minutes
#58
what you mean why the blower cam? That cam isnt exactly a all out blower cam. It should make good power all throughout the power range and be a nice cam in a 5000lb plus truck. It should start to pull about 2800 and pull well past 5500. If the manifold isnt restricting.
Is the cam advanced +4 upon install? It most likely has +4 grounded in it.
#59
#60
What is the timing at WOT? It should be running at least 28*, if not 30*. I'm running 33* and it has ***** at all rpm. Top end it never stops pulling.
