Whats next?
Old Feb 18, 2007 | 07:53 PM
  #41
v8
17,16,15,14,13,12,11 Drvr
with that cam did you change out the valve springs, it could be floating the valves if not, did you look at the first video and notice how quick it shifted after down shifting?
Old Feb 18, 2007 | 08:12 PM
  #42
LS1TRUCKGUY's Avatar
all that dirt is weighting you down!! j/k from what it sounds like, i would check the tune, and get an u/d pulley. ap2002 picked up almost 2 tenths with a bolt on/cam 5.3 with just the asp pulley. i picked up 6 tenths going from 3:42's to 4:10's. it felt just a tad bit quicker, but i couldnt tell the true difference until i went to the track.
Old Feb 18, 2007 | 08:25 PM
  #43
dropkick13's Avatar
what gears did you used to have...that sucks you didnt get anything out of the 4 10's.
Old Feb 18, 2007 | 08:51 PM
  #44
onebadrubi's Avatar
Get that timing fixed and **** it bout 6300+.
Old Feb 18, 2007 | 09:08 PM
  #45
RoosterMcCandles's Avatar
He had 3.23's...
Old Feb 18, 2007 | 09:23 PM
  #46
Phantom's Avatar
11 Second Club
Yes we put ls6 springs in it...
Before the 4.10's (3.23's) with the tow haul on, it would hold to about 40mph. Now with the 4.10's it only holds to just under 35. That first race was from 32ish. Any ideas? Think maybe we can just take the EFI Live out and street tune the shift points? Everything else is dead on...Besides the pulling timing at 5300
Old Feb 18, 2007 | 09:28 PM
  #47
Mine doesn't shift out of 1st until about ~45ish...
Old Feb 18, 2007 | 09:31 PM
  #48
Phantom's Avatar
11 Second Club
Hopefully its as easy as takin it out and gettin the shift points better...my luck it'll be another f*ckin day of dyno tuning
Old Feb 18, 2007 | 09:40 PM
  #49
bigbadwolf54's Avatar
13 Second Truck Club
just a suggestion but......I only use the WOT upshift RPM table for my WOT shifts and I dont try to match speed/RPM, that way it shifts as soon as it reaches the desired RPM. I'm guessing you've re-tuned for the gear change???
Old Feb 18, 2007 | 09:42 PM
  #50
Phantom's Avatar
11 Second Club
the only retune we did was for the speedometer...
