what size supercharger for the 422?
Old Oct 22, 2004 | 10:35 AM
RED2K's Avatar
Default what size supercharger for the 422?
I was told that a radix wont move enough air for my 422. They said it would not move enough air across the entire rpm range. { like cut out at 4000 rpm}. Anyone know abou tthis.?????? bueller bueller?
Old Oct 22, 2004 | 10:40 AM
2toneblown's Avatar
No way will that thing make any boost on that motor, I have a 408 and it probably would make maybe 2#s of boost. Thats why I am doing an F1R.
Old Oct 22, 2004 | 10:49 AM
ATI is your best bet for SC. They have them big enough to make 19# on a big block, so a 422 you'd be set. Are you going with something other than the truck intake? Hurry and get that beast in, we need a new fastest truck. Its been 1 guy running things here for nearly 2 years now. Time for some new blood.
What ever happened to Kelly anyway?(c3c5)
Old Oct 22, 2004 | 10:57 AM
You could always go turbo.... I'm sure a T67 with some different comp wheels in it could make some serious power without running out of breath.
Old Oct 22, 2004 | 11:04 AM
sfj
agree with snake eater im not sure about the blower but hurry up and get that thing in and see what you can do
Old Oct 22, 2004 | 11:07 AM
most definetly can't hold up to that. you will need exactly what snake eater said or you could get a large turbo to run it. what compression is the 422 and what cam did you decide to go with. also are you changing out the tranny?
Old Oct 22, 2004 | 12:11 PM
RED2K's Avatar
Well the c.r is about 11.5 to 1 so I guess I might as well stick to spray. It will hold up to a 300 shot so. If I get another set of heads I will be back down on the c.r so maybe I will worry about it then
Mr. Sandog's Avatar
If you're married to the idea of a supercharger, you're either going to need a centrifulgal (i.e. ATI) and will have to settle for the spool-up boost lag which is similar to turbo lag, or if you want off-idle boost, the intercooled 3.3L Whipple that Starr Performance sells in Australia. The 3.3L Whipple is good for up to 1,000 HP, but the problem is that the price is well North of $10,000 U.S.
Old Oct 22, 2004 | 12:17 PM
2toneblown's Avatar
Well I got some brackets fabricated up a F1R and got some other stuff to stop the belt slippage and flexage then i an hoping that it will hold on to a belt and make some boost. If this works then thats what I would suggest to you.
Old Oct 22, 2004 | 12:20 PM
RED2K's Avatar
yeah
I am going to have to go ahead and say NO to that right now. I guess I could always sell a kidney.
