What plugs/wires?
Old Sep 24, 2004 | 06:13 PM
  #21
nativetexan's Avatar
13 Second Truck Club
I had the TR-55 plugs and Taylor Spiro-Pro wires on my former truck. I had no problems at all. Excellent quality and fit with the wires.
Old Sep 24, 2004 | 06:54 PM
  #22
black_yukon's Avatar
I've had Taylor Spiro-Pros for over a year with YOG headers and have had no problems yet. I didn't know they made ThunderVolts for the trucks.
Old Sep 24, 2004 | 07:37 PM
  #23
shandy294's Avatar
Does the iridium give a hotter spark or just longer life? My truck only has 7k so it's got the original plugs. I have a 93 Civic (no fart cannon or other bs) driver...I just put some Bosch Platinum + 4s in it for the second time...had 60k on 1st set...no gap to set . Whether multiple ground electrode plugs are better for performance,I don't know. It seems to run better with them. I used Champion Copper Plus plugs in for 40k...they were good...seemed the same as the originals which were Nippondenso.
How any of that relates to use in Vortec V-8s or Ls1s,not sure. Modern ignition systems put out good spark and there are a lot of good plugs and wires out there. My first car had points...they sucked compared to newer stuff...it had a dual point distributor (340 Mopar) and Champion N 9Y plugs. Changed them about every month because it'd break-up at about 4,800. Engine had 10.5 cr...my 4.8 is 9.5:1 which is semi-high compression. I think if you are at or near stock,it doesn't matter that much what you use.
Old Sep 25, 2004 | 06:29 AM
  #24
What part number do you guys use on the MSD 8.5 wires. I have an '04 Z71 Suburban Vortec 5.3L FWIW. Thanks!
Old Sep 25, 2004 | 09:42 AM
  #25
budhayes3's Avatar
PT's Slowest Truck
The main benefit of iridium is longer life. It's a stronger metal than platinum and has a higher melting point.
Old Sep 27, 2004 | 10:48 AM
  #26
marc_w's Avatar
I can get you that info tonight...
EDIT: Actually, they were 32829's.
The LS1 car wires would not work on my truck. WAAAAAY too short.
Old Sep 27, 2004 | 03:54 PM
  #27
Trey's Avatar
I had the same problem with the taylors and am now just running stock ones with AC plugs, might order a set of MSD before to long.
Old Sep 27, 2004 | 05:19 PM
  #28
one03sierra's Avatar
Formerly one92rs
Talking
heck before and when i started using nos i was using the tr55's in mine. i think i got the whole set for 20.00 or less. i am running the 10.4 taylor camaro wires since i have the small round coil packs that i got from parish.
Old Sep 28, 2004 | 05:49 AM
  #29
leochevy2001's Avatar
When did they start using the round coil packs?
Old Sep 28, 2004 | 05:57 AM
  #30
Formerly one92rs
Talking
they have been using them on and off. i think they just throw on what they have at the moment.
