what is pcv valve? and how/when to change
Old Apr 8, 2004 | 09:10 PM
Phatchevy's Avatar
Default what is pcv valve? and how/when to change
hey yall. i was just wondering what it is and what it does. also how to change it out. thanks for the help....
Randy
Old Apr 9, 2004 | 05:05 AM
Flyer's Avatar
The PCV valve is what lets freash air into the engine, the crankcase area. It stands for Positive CrankCase Ventilation. More than likely yours doesn't need changing. It's on the drivers side valve cover all the way on the back edge, like where the oil fill neck would be if the motor were turned around backwards. There is a hose attatched to it. Just pull it out of the valve cover, if you can see through it with the hose off ... it's fine. If you can't see thorugh it, you need to use a better quality oil and/or change it more frequently and replace the PCV valve.
mhorn0817
Jul 8, 2017 01:54 AM
The_W
Oct 28, 2015 09:00 PM
Noah Burns
Sep 7, 2015 05:50 PM
jroctpb
Aug 11, 2015 03:52 PM
Mzay
Jul 6, 2015 11:03 PM
