What PCM to use a T-56 behind a Gen III in a 99-02 Silverado?
Old Oct 17, 2010 | 12:34 PM
DarkCharisma's Avatar
Originally Posted by BBC+T56
Putting a T56 in moves the shifter way back on the floor. Bench seats are needed and there is no room for a console in the middle. I would recommend at least 4.11 gears for the rear. In my 92 with stock gears, 2000 rpm in 6th gear was 90 mph. 1st gear needed to be lower to to get a load started. A T56 makes pickups fun to drive but I wouldn't recomend it if you using it to pull much.
From what I can find, the ZF-6 doesn't have a much deeper first gear, and that doesn't leave me much else for 6-speed manuals. I suppose I could do an NVG4500 but I really want that double OD.
Old Oct 17, 2010 | 03:29 PM
BBC+T56's Avatar
Registered User
Ketis, that looks nice! I put a T56 in my 92 and the shifter is probably 10" farther back than that. What is the deal?? Mine had a big block in front of it. But I was told the distance from the motor mounts to the back of the motor was the same on a 454 and 350. 454 is only longer in front of the mounts. That not true? Or is it because you have a newer 5.3 moves it forward?
Old Oct 17, 2010 | 03:31 PM
BBC+T56's Avatar
Registered User
NV4500's don't shift all that smooth. I would use an automatic first.
Old Oct 18, 2010 | 10:48 AM
That's unfortunate. What would make the T-56 unsuitable for pulling 6-7k during the summer? Lack of proper clutch selection, too much total weight? I'd obviously have 4.88's to turn the 35's.
Old Oct 18, 2010 | 11:01 AM
JakeBrakeIH's Avatar
You would need A LOT more gear for 35s! I have 4.88s with roughly 30" tires... Turbogibbs on here has 5.13s with the same size tire. You'll need a lot higher gear to even just get performance back to stock with those big tires.
Old Oct 18, 2010 | 11:41 AM
Okay, that's unfortunate. I can only go to 5.13's with the 8.25" front differential in the half-ton... With the automatic the 4.88's were better than stock gearing (35" mud terrains + 4.88's with a 4L60e) however I just chew apart automatics, was looking for something a bit more robust as well as fun...
Damn. Off to see what availability there is for the ZF-6 in a truck...
Old Oct 18, 2010 | 11:34 PM
PathfinderJr's Avatar
Some fella on here swapped in a ZF-6 into an Avalanche. Do a search and I'm sure it'll pop up.
Old Oct 19, 2010 | 11:01 AM
Ketis's Avatar
i am unsure on the shifter loaction. the shifter comes up about an inch or so in front of the center of the hole, so i made a custom shift lever that offsets it to the left about 3 inches and back one inch. i dont have a pic, but when i pony up the cash for a mgw shifter, ill get some pics of the lever.
XL7
May 5, 2022 01:48 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
mzoomora
Jan 3, 2016 07:06 AM
Denali08
Aug 9, 2015 04:34 PM
Suburban2500
Jul 19, 2015 04:50 PM
