What is needed to make the 14's?
Old May 1, 2005 | 08:55 PM
ThunderZ28's Avatar
12 Second Club
Originally Posted by 02CHEVYRACING TRUCK
what are you running now thunder?
nothing new as of yet.. havnt really been when conditions where ideal to run...
Old May 1, 2005 | 09:01 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
He said no stall and no gears. Get a nelson tune the lt's full exhaust without a flowmaster, intake, shorter tires, and a posi if you dont have one that she be more than enough for high 14's. The cam with some tuning should drop you into the mid 14's to low 14's. If you do decide to get the tb stall it stalls at about 2600rpm instead of the factory 1700ish you keep the tow rating and gs mileage its a good mod for around 300 bucks but you do have to pull the tranny. If you do the stall put the transgo hd-2 shift kit and a vette servo in and nelson can take all the torque management out of the copmuter and it will make your truck run good. The shift kit will also make your tranny last longer when towing too.
Old May 1, 2005 | 09:10 PM
ThunderZ28's Avatar
12 Second Club
hate to break it to him, but a stall is going to get that thing off the line better than anything else you can buy..
even long tubes are not going to drop your times as much as the verter will
specially since it is a 4.8L..
the 2800 vig that I have can and will tow a vehicle on a 16' trailer.. done it.. and it didnt over heat the trans or cause any problems..
as far as the gears go.. 3.73's are not going to change his gas mileage hardly at all, if any.. since he is rolling on 3.42's..
Only offering the info he wanted.." how to get into the 14's?"
makes it harder to since he has a 4.8L
with the setup I mentioned earlier.. I was running mid 14's on stock internals..
stock cam.
only mods where a K&N air filter,
3.73 gears,
2800 stall
Eaton posi
28 inch tall, tires
and true duals through edelbrock shorties.
Bumpers
Aug 4, 2024 09:44 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Slammed96
Jul 27, 2015 07:22 AM
Jake75
Jul 22, 2015 09:20 PM
Sbrown06
Jul 9, 2015 09:21 AM
