What Motor is this?
Old Feb 2, 2008 | 09:33 AM
SheldonZ28's Avatar
Default What Motor is this?
Hey Everyone.
I picked up a 5.3L Motor from a local. He said its a '03, however, there was a tag on it that said '04!
I need to determine the year for the wiring. Not sure if it means anything, but the ECM connectors are Green & Blue.
Here are the casting numbers i got off it (dont seem to match anything online)
Passenger side of block by oil pan
S04
Behind passenger head, on back of block:
12567392
Infront of Passenger Head:
06K02
Heads:
706
Thanks!
Old Feb 2, 2008 | 04:02 PM
jakebdb56's Avatar
Casting Number 706
Head: 1999+ LR4 4.8 Litre Truck
1999+ LM4 /LM7 5.3 Litre Truck
Material: Aluminimum
Part Number:
12559852
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Old Mar 10, 2008 | 04:25 PM
Nmanuel01's Avatar
Have you seen this cating number 1567392?
It is either a 4.8 or 5.3. It has a supercharger picked it up from a friend
Old Mar 10, 2008 | 10:55 PM
budhayes3's Avatar
PT's Slowest Truck
That kinda looks like a part number...
Old Mar 11, 2008 | 12:06 PM
Nmanuel01's Avatar
man that sucks! I know the supercharger is from magnuson. it has a s/n number. carb number but no part number. Where on the engine block would be the casting number to find out what motor it is. on the back it has a 4.8l and 5.3l. The head has the 706 casting number on it
Old Mar 11, 2008 | 12:23 PM
jkwalkercchs's Avatar
pull the heads a 5.3 has dish pistons a 4.8 has flat tops
and yea before some1 says it there are some flat top 5.3s out there but i doubt u got one of them
Go5.3tt06
25
Sep 4, 2016 10:25 AM
Glenn98ZM6
Sep 18, 2015 07:31 PM
dantheman1540
Sep 18, 2015 03:03 AM
03chevytruck
Sep 14, 2015 09:15 PM
