What head gasket should I use?
I am doing LS6 heads on the 5.3L block. There are different head gasket part numbers for different years of LS1 motors...I didn't think there was any difference
I was thinking of going with stock multi layer steel GM head gaskets. Is something better for the 10psi of boost that it will see? I think the stockers will be fine, but which ones to get with all of the different part numbers - I couldn't even find a '99 5.3L truck head gasket pt#?
I believe you have to use 5.7 gaskets on that application because to of the reduced diameter of the 5.3 bore. As far as what thickness to use, you got me. Since the new heads are already going to reduce you comp, I dont know how low you want to go. With the thickest gasket, you could just poor on more boost.
Does anyone know why there is a difference in part numbers for the early vs. later years of an LS1 head gasket? Are the gaskets really even different?
BigKID, I have heard that increasing head gasket thickness increases risk of blowing out the head gasket. I see your point though of lowering compresson to run even more boost. It is addictive
Originally Posted by Ryan23silverado
Thanks for the advice guys
So later model Multi Layer Steel head gaskets it is.
So later model Multi Layer Steel head gaskets it is.Trending Topics
Hey twobit why would you do that if the 5.7L has a 3mm larger bore? Doesn't the gasket overlap the bore some? Is it all working well?
Ive driven the truck 1000 + miles and have had no issues.
BIGD4504
Jul 28, 2015 11:46 AM
