What fuel pressure should I run?
Old Apr 24, 2009 | 09:48 AM
Dark Halo's Avatar
I am at 60 for now, but I may experiment. My tunner had also recomended running 58-60
Old Apr 24, 2009 | 02:22 PM
dirt track racer 81's Avatar
Originally Posted by thunder550
If the injectors are designed for 3 bar I would run them there. I think the spray patterns get distorted when you turn the pressure up higher than designed, plus the lower pressure is easier on the pump.
ive always wondered if a higher pressure could make the spray pattern different..
alot of people run it like this tho..
Old Apr 24, 2009 | 06:30 PM
Dark Halo's Avatar
has any real testing been done on this?
Old Nov 26, 2009 | 08:01 PM
JOHN1L40's Avatar
Is this, 60 psi, set with vacuum removed? So it would be 60 psi max under load and a few ponds less unloaded?
Old Nov 27, 2009 | 10:24 PM
thunder550's Avatar
High on diesel fumes
Yes, you would set the desired fuel pressure with the engine off, so there would be no vacuum on the FPR. Once the engine is running the manifold pressure will dictate the final fuel pressure.
Old Nov 30, 2009 | 08:46 AM
BigKID's Avatar
You need to run at the fuel pressure your tunner recomends so that your injectors are scaled properly. With 42# injectors, there is no reason to deviate from the stock spec pressure.
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
GMCtrk
Jul 17, 2015 06:39 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
slowlsx
Jul 13, 2015 04:18 AM
