What fuel pressure should I run?
Old Apr 21, 2009 | 02:07 PM
Dark Halo's Avatar
Default What fuel pressure should I run?
I have an edelbrock adjustable FPR and lucas 42.29lb/hr injectors, I know the injectors are a 3 bar injectors but at what psi should I run the regulator?
Old Apr 21, 2009 | 02:16 PM
dirt track racer 81's Avatar
i have my fp set to 60. i have the same injectors if they are rated at 43.5 psi.. they come out to 58-59 lb injectors
Old Apr 21, 2009 | 02:37 PM
Dark Halo's Avatar
you have been a big help through out this intake swap thanks
Old Apr 21, 2009 | 11:59 PM
Dark Halo's Avatar
will this harm them in the long run?
Old Apr 22, 2009 | 08:11 AM
white lightning SS's Avatar
59-60 psi will not cause any issues with the injectors.
Old Apr 22, 2009 | 06:00 PM
Dark Halo's Avatar
thanks for the help
Old Apr 22, 2009 | 06:19 PM
Mangled03gmc's Avatar
Baltimore Whore
This is correct...
Old Apr 23, 2009 | 09:40 AM
TXsilverado's Avatar
is stock 58psi or 60?
Old Apr 23, 2009 | 12:41 PM
stock is 58psi.
Old Apr 23, 2009 | 01:16 PM
thunder550's Avatar
High on diesel fumes
If the injectors are designed for 3 bar I would run them there. I think the spray patterns get distorted when you turn the pressure up higher than designed, plus the lower pressure is easier on the pump.
