What do you guys thing about these cam specs
226/234 @ .050 628/604 113 lsa
With this cam and an LSA supercharger with a 2.55 pulley, it put down 629HP/620TQ with 11 psi. The kicker, at or off idle, before 2000 rpm was 520 lbft of torque!!! Stock ly6 except a cam and spring swap. What do you guys think? Granted it was in a Chevelle, I think?, What do you guys think?
So what that means is,
It chops a little and it keeps cylinder pressures manageable.
If there was less overlap, it would probably make more torque down low but at the risk of higher cylinder pressures.
For a truck, you'll never see that number even if you swapped that drivetrain in.
But it would be close....and fun.
ly6 = 6.0
Horsepower: 385 hp @ 5600 rpm
Torque: 400 lb-ft @ 4400 rpm
6.0/lsa cam/2.55 only really good numbers! c7z's are only putting down 550ish to the ground
kinda has me rethinking my 6.2/boost build
