What do you guys thing about these cam specs
Old 11-29-2017, 08:12 PM
About20ninj45's Avatar
Default What do you guys thing about these cam specs
226/234 @ .050 628/604 113 lsa
With this cam and an LSA supercharger with a 2.55 pulley, it put down 629HP/620TQ with 11 psi. The kicker, at or off idle, before 2000 rpm was 520 lbft of torque!!! Stock ly6 except a cam and spring swap. What do you guys think? Granted it was in a Chevelle, I think?, What do you guys think?
Old 11-29-2017, 10:16 PM
GMNUT's Avatar
Stock blower? If everything else is stock I'd say those numbers are great. My V bone stock put down 455/450. I would love to get close to those numbers with just a cam swap lol.
Old 11-29-2017, 11:55 PM
Yea, stock blower with pulley swap. 91 octane. The fact that he has that much tq down low is crazy! For a truck that would be insane!
Old 11-30-2017, 03:46 AM
Mod with training wheels
smokeshow's Avatar
Garbage, will never work.
Old 11-30-2017, 07:49 AM
madmann26's Avatar
That cam has 4.00 degrees of overlap.
So what that means is,
It chops a little and it keeps cylinder pressures manageable.
If there was less overlap, it would probably make more torque down low but at the risk of higher cylinder pressures.
For a truck, you'll never see that number even if you swapped that drivetrain in.
But it would be close....and fun.
Old 11-30-2017, 10:04 AM
He could have went more, but didnt want to run meth. Heres the vid.
Old 12-01-2017, 10:50 AM
turboal1's Avatar
Default Wtf
If thats a true dyno pull, that's totally awesome
for a stock motor with just a cam. is it a 5.3 or a 6.0 ?
Old 12-01-2017, 12:23 PM
stroker87's Avatar
ly6 = 6.0
Horsepower: 385 hp @ 5600 rpm
Torque: 400 lb-ft @ 4400 rpm
6.0/lsa cam/2.55 only really good numbers! c7z's are only putting down 550ish to the ground
kinda has me rethinking my 6.2/boost build
Old 12-01-2017, 03:59 PM
4 gen 6.0
Old 12-01-2017, 06:22 PM
Originally Posted by stroker87
ly6 = 6.0
What boost build are you doing?
