What was decided about Suburban brakes on a Silverado
Old Feb 23, 2008 | 07:23 PM
skyhighsami's Avatar
no title here
Default What was decided about Suburban brakes on a Silverado
I have an 05 Silverado and I remember reading that the Suburban had 2 piston rear calipers. I was wondering if anyone did the swap. My truck has rear drums and I was thinking about seeing if I could get a rear from the junk yard and take the brakes off and put them on my Silverado.
Old Feb 23, 2008 | 07:57 PM
formerly 20032wdsilverado (8/29/2011)
Im not 100% sure but isnt there 4 bolts that hold on the backing plate and couldnt you just swap them? I know that on my disk brake rear end, it has 4 bolts on it.
Old Feb 23, 2008 | 08:25 PM
no title here
I am not sure I will look when I am taking my lowering kit off though.
Old Feb 23, 2008 | 08:33 PM
Truckshop's Avatar
my 04 crew cab has 2 piston rear calipers.
Old Feb 24, 2008 | 09:19 AM
02BlueStepside's Avatar
I am fairly certain that Scream did the swap
Old Feb 24, 2008 | 07:57 PM
built408's Avatar
I did the swap... Just need the rotors, calipers, and caliper brackets...
Old Feb 25, 2008 | 08:11 AM
no title here
How does it stop compaired to stock? I will likely go to get the caliper brackets from the dealer. I am sure they don't cost that much and then pick up some calipers from the junkyard and use them as a core. What year did you get your brakes off of.
Old Feb 25, 2008 | 08:18 AM
built408's Avatar
Think it came off a 2002.. The rotors are almost 1/2 thicker.. It doesnt have brake fade as much when doing alot of long hard stops... Other than that it feels the same. I dont do any towing so I couldnt tell you if it helped out there..
Old Feb 28, 2008 | 09:51 PM
no title here
What brake pads are you using and what lines? All OEM?
Old Mar 11, 2008 | 07:39 AM
Scream's Avatar
MOOBIES Moderator
I looked into it but never did it. I couldn't get any difinitive information on what all it took, and if it was even worth it or not.
I just did SS lines and Brembo cross-drilled rotors.
Steve-O-08
Apr 19, 2018 09:32 AM
Staggered 02
Aug 11, 2015 07:54 AM
Ajaay
Jul 8, 2015 09:29 PM
mrgrim
Jul 8, 2015 08:12 AM
