WHAT CAM FOR 6.0
Old Apr 17, 2003 | 01:09 PM
BigTex's Avatar
Default Re: WHAT CAM FOR 6.0
Picking a cam will depend on what you want out of it. I thienk the comp 212/218 cam is well suited for the 6 liter motors. It should keep a good amount of torque as well as make more power. If you want a higher HP cam and are willing to sacrifice a little torque, there are some other cams to choose from. Do a search in this section for some good info.
Old Apr 17, 2003 | 03:03 PM
ryan99chev's Avatar
Hey Big Tex do you need new springs with that cam or can you use stock ones. I don't pull a trailer and i just like to play around. I have a k&n with the kirk and straight exhaust. I have a low temp thermostat in it also. I want to get headers and pulleys too. Let me know about the springs pleace.
Old Apr 17, 2003 | 06:15 PM
BigTex's Avatar
With the 212 cam, you can run 01 or 02 LS6 springs from GM. If you go with a bigger cam, you should get comp 918 springs. They handle higher lift and have more seat pressure. If you intend to install a torque converter, you can go more aggressive on the cam choice and not notice the loss of low end torque.
Old Apr 18, 2003 | 12:45 AM
ryan99chev's Avatar
Default WHAT CAM FOR 6.0
Hey i am new to the board so i bet this has been asked many times before. I have a 99 chevy reg shortbox Z71 pick with some mods. I am getting ready to install a 2001 6.0 in it right now and since it was all out i was wondering what cam to go with and springs. I have the hpp reprogrammer also. Let me know and thanks
OHsixLS3
Dec 27, 2016 09:30 AM
greedygenius
Sep 3, 2015 06:51 AM
JordanH
Aug 8, 2015 07:59 PM
steves86ta
Jul 28, 2015 10:21 AM
all_individual
Jul 13, 2015 11:01 AM
