What is the best intake for a 5.3???
Old Dec 31, 2008 | 08:38 AM
  #31
beastmode's Avatar
Import Moderator
Yup... just stick with the truck intake dude... LS6 is gonna cost you $800+ and for your mods it wont be worth it. Maybe pick yourself up a set of 8.1 injectors though
I might be running this same cam in my 5.3 when I do my 4wd conversion... only I might go with a TB stall
Old Dec 31, 2008 | 03:28 PM
  #32
HotRodV6's Avatar
SyTy Speed Shop
Originally Posted by Faze2183
where would i find one?
heres one i found the other day on ebay
http://cgi.ebay.com/ebaymotors/6-0-L...QQcmdZViewItem
When i bought mine early last year i couldnt find any like this on ebay, so i just ordered the bare intake from gmpartsdirect for 150 shipped and then ordered the 90mm truck TB for 160 shipped and am making custom fuel rails and for now i plan to reuse the stock injectors on my truck now.
Old Jan 2, 2009 | 01:56 AM
  #33
Faze2183's Avatar
I saw that one teh other day as well... Youd almost think those things would be moarrrrr common on ebay... Do you have a part number of yours by chance? Got some pics of progress?
Old Jan 2, 2009 | 07:38 AM
  #34
litreddevil's Avatar
Banned
well i can belive that a ls6 intake will not show any gains "but" you do have to have te tune and set up for the intake
1-you will need a higher stall
2-tune for it
3-have the right cam for it
4-and make sure you are making enough power to need it are tunring the motor up were the stock truck intake is droping off.
but remember it has alot to do with tunning.tunning is everything on these motors
you can not just throw stuff on the motor and think it will run it's best
Old Jan 2, 2009 | 08:33 AM
  #35
2-tune for it
Ok. Thank you. I was really thinking about doing it anyway. It will probably be something later on that I will be doing. Thanks for the info.
Old Jan 2, 2009 | 10:35 AM
  #36
1FastBrick's Avatar
Custm2500's Rude Friend
Try this thread out.... actual testing here... In the picture I posted of the dyno test, the truck intake actually stays a head of the LS6 manifold ever so slightly. But there basically dead on with each other. Hence no real advantage or gain. I would really like to see the new edelbrock manifold tested against these and the TBSS mainfold. I know the TBSS shows a gain over the stock truck and I believe thats partially because it uses a 90mm TB rather then the factory 78mm TB that came on our trucks....
https://www.performancetrucks.net/fo...d.php?t=397720
Old Jan 2, 2009 | 11:12 AM
  #37
Ok. I actually read on another site where some people are getting gains and others aren't. It all depends on your mods. To me it's not worth a chance. I am just going to go with guarunteed mods.
Old Jan 3, 2009 | 06:51 PM
  #38
HotRodV6's Avatar
SyTy Speed Shop
The p/n for the bare intake i ordered is 12580420 150 shipped from GMPD and the LS2 90mm truck TB is p/n 12580760 161 shipped. And i just ordered it and its on national backorder.
I havent made and real progress with the swap, still getting the parts, i plan to get some aftermarket LS2 aluminum fual rails and use an aeromotive adjustable regulator i already have and my stock injectors for now.
Also i was planning on sending the intake and TB to LS2portworks and have them ported before install also, but well see how my cash flow looks when i get the TB.
Old Jan 8, 2009 | 09:05 PM
  #39
03_SS_22's Avatar
Originally Posted by wastedrubber
that seems to be your best bet unless you have a lot of supporting mods that require some heavy breathing.
x2...
B.love18
Sep 21, 2015 08:31 PM
mr03silverado
Aug 13, 2015 11:40 AM
05GMC4.8
Aug 7, 2015 09:55 PM
steves86ta
Jul 28, 2015 10:21 AM
04450r
Jul 24, 2015 01:58 AM
