what after market fuel system do you guys
From: Somewhere between Auburn, AL and Columbus, GA
fuel system as in injectors and pump? If this is what you are talking about then you could use some 8.1 ltr marine injectors(42lbs) and a walbro fuel pump. I would be surprised if you didnt already have something along these lines though since you have a 6.0 ltr w/10lbs of boost.
Originally Posted by OUT2WIN
He still has stock injectors and stock fuel pump. How hard is the walbro to install?
I installed my walbro from the top, removing the bed. It's really easy that way. 8 bolts a couple of screws on the filler neck and unplug the wire harness at the back. Then I just used a cherry picker and 4 motorcycle straps to lift the bed, and the top of the tank is right there for easy access. I think it took me about 45 minuets to swap my fuel pump.
What did you have to do to in the tank to get the pump to work? do you have to mod the bucket or will it just drop in , and which walbo pump did you use ?
i have the twin intank set up from racetronics and some 95lb injectors, so far it is working for me. i still have stock lines and rails. the only problem is they cut up the bucket and you end up needing to run about 3/8tank of gas minimum or you may suck air.
for a more mild set up just a $120 inline pump will go a long ways.
Originally Posted by MR1911
I have to do this real soon on my 2k serria, my pump gets real noisy at 1/2 tank
lxcoupe
Jul 21, 2015 02:12 AM
