What about this grind
Old Aug 21, 2003 | 08:25 PM
RED2K's Avatar
Default What about this grind
212 214 525/528 lift on a 110 or 112? I am not please with my cam and since it will be quite a while before a engine swap I thought i might like to have more low end back. I still need to pull a 3000 lb racecar and a 18 ft trailer so i thought this one wouldnt be bad. I know the 110 is tight but I gotta her it a little
Old Aug 21, 2003 | 08:42 PM
Banned
Default Re: What about this grind
should perform just about the same as the one you have now, maybe a little more lowend.
Old Aug 21, 2003 | 09:05 PM
RED2K's Avatar
Anyone else here? Maybe one that knows what they are talking about? I was thinking about that or a 208-210 518 /525 on a 112 with 4.10s. Should pull like madf i would think. Anyone got stock cam specs for 2000
Old Aug 21, 2003 | 09:23 PM
67SS509's Avatar
10 Second Truck Club
RED2K...sure is strange, with the same cam you don't have enough bottem end with a 5.3 and in the 6.0 I don't have enough top end. What rpm do you shift at?
Old Aug 21, 2003 | 09:25 PM
RED2K's Avatar
I should shift lower but it is set at 6200 rpm. I have 3.42 so I am sure that hurts me but i lost alot with this cam down in the lower rpms
Old Aug 21, 2003 | 10:21 PM
BigTex's Avatar
Get a cam with the XE lobes and lift in the .550s. Maybe a 212 212 .55x 114 lsa +4 advance cam.
Old Aug 22, 2003 | 07:45 AM
Flem's Avatar
If your looking for more low end I would go with Tex's on the XE's anf the 114LSA and +4 advice but around a 208 intake duration. my .02
Old Aug 22, 2003 | 08:33 AM
GREGGO's Avatar
I know a guy that has this one for sale:
Brand NEW!!!! Comp 212/212 522/522 112lsa +4
And he will drop the price to $325 Shipped
Old Aug 22, 2003 | 09:14 AM
JWRENCH's Avatar
If you mean the stock 4.8,5.3,and 6.0 cam, the specs are...
Part number 12560967
intake lift .457
exhaust lift .466
intake duration 191
exhaust duration 190
lobe sep angle 114
intake lobe center 112
exhaust lobe center 116
They all pretty much use the same cam except for the '99 model 4.8 and 5.3's which the LSA was 115.5, and the lobe centers were 118 intake / 113 exhaust.
And also the 6.0's changed for 2001 and up to this...
Part number 12561721
intake lift .467
exhaust lift .479
intake duration 196
exhaust duration 207
lobe sep angle 116
intake lobe center 117
exhaust lobe center 115
Found these specs in a great book I picked up the other day.
LS1/ LS6 Performance
thompson
Dec 27, 2017 06:48 AM
hodge9386
Oct 25, 2015 01:26 PM
alex226
Oct 14, 2015 07:23 AM
twake_410
Sep 25, 2015 10:09 PM
mayko
Sep 7, 2015 12:24 PM
