Went to the dragstrip.
Old Apr 22, 2005 | 10:35 AM
  #31
Originally Posted by lotzafun
The reason that I did away with the MAF was that I could not get rid of surging up and down at idle, and LTFT would not lean out, it was always rich. So I tuned my truck using HP Tuners to run without the MAF sensor. Also not into running too many RPM's, so will stick with 5,200 rpm shift points. This is a daily driver, so will look for other ways to get my times down, maybe shed some weight off the truck. Has anyone found CalTracs to be helpful on a full size truck?
5200 is way too low, hell I think stock is around 5600. You should AT LEAST be shifting at 6200. You're not gonna hurt anything by going to 6200 and it won't affect daily driving.
Old Apr 22, 2005 | 10:37 AM
  #32
13 Second Truck Club
i would definately move the shift points way closer to 6K if you want to pick up some time. you will struggle with performance with low shift points like that IMO
Old Apr 22, 2005 | 10:57 AM
  #33
14 Second Truck Club
Originally Posted by F8L Z71
Also, even on the stock cam (peaks at 5200rpm) reving it out to 6k and staying in the lower gears longer does indeed improve 1/4mile times. That is why people see a .4 gain in the 1/4mile with the stupid HPP3.
The other reason for gains when you hold the gear longer is that you put it further into the power band after the shift. Even if you are past peak before you shift the power is not dropping off that bad to hurt it that much, plus you are in a meatier part of the power band after the shift, which reduces the drop off in power.
I also dont see the reason for installing a cam and not really using it. The main way most cams make horsepower is by raising the power band further into the higher rpm's, even the additional torque is usually at a higher rpm which is why most cams require a stall to work properly(driveability). You are adding stress to the motor by just adding more power in general, so why not use all that power? It isnt like you are running it to 6k every shift.
Old Apr 22, 2005 | 11:00 AM
  #34
BeefTip's Avatar
From: Somewhere between Auburn, AL and Columbus, GA
My 97 silvy shifts at 5400-5500 on the shifts, the vortec 350 peaks way lower than the gen 3 motors, much less a gen 3 with a cam.
Old Apr 22, 2005 | 11:09 AM
  #35
i agree with mzommora when he said its not like your running it to 6K every shift. probably only once in a while
Old Apr 22, 2005 | 11:13 AM
  #36
F8L Z71's Avatar
I agree totally. I was just keeping things simple. LOL Shift extension is very important.
I'm a junkie so my truck shifts at or over 6k all ther time. I'm the type that has to floor it at least 3-4 times a day.
Old Apr 22, 2005 | 11:15 AM
  #37
aren't we all, LOL
Old Apr 22, 2005 | 11:37 PM
  #38
02sierraz71_5.3's Avatar
Just looking for some answers after going to the dragstrip. The best that I could run was 15.3 @ 85 MPH. The truck did have some traction issues, but the main issue it had was when it went into 3rd gear. The truck would pull hard all the way through 2nd gear, but when it hit 3rd gear it would drop rpms to around 3,000 rpm's and felt like a boat anchor had been tossed out the back.
My questions is this. Has anyone had this same problem, or have I overlooked something. With the mod's that I have made it should have been in the 14's but some of the tire spin hurt on ET. Seems like it should pull as hard in 3rd as it does in other gears, but it feels like it just quits pulling.
If anyone has some ideas, please share them here, my mod's are listed below. Thanks.
as I posted earlier I was having the same problem I did some research and its all about the tuning look at this link and copy the table values one of the guys is using
https://ls1tech.com/forums/showthrea...locking+up+3rd
I was out racing some buddies tonight and couldnt figure why it always fealt like a dog when around 80 in third I couldnt get the converter to unlock I looked at the
TCC apply/release speed vs gear
and the answer was apparent the converter will lock in third at 80 no matter what so after studying tables came across this link and the guy that posted the screen shots seems to have worked out some really nice tables.
Now all I need is a laptop to start tuning my next mod is going to be hp tuners fo sho
Old Apr 23, 2005 | 02:34 AM
  #39
CashDudeHomie's Avatar
I second raising the shift points. 5800-6000 is plenty conservative. 5200 is a waste. Nothing is gonna break if the cam swap was done properly. Good luck. You should be able to hit at least 95 mph.
Old Apr 23, 2005 | 01:55 PM
  #40
lotzafun's Avatar
Wow, this is some great info put up here, will have to fire up the ole laptop and make some changes. Changing the shift point to 6,000 and then will make lock up changes. Will look for next day that I can get to the track and try out changes. Still feel that 14's are achievable without changing gears.
CashDudeHomie - What are your mods to be able to run 13's
