Welded flanges on your pacesetters
Old Nov 8, 2006 | 12:01 PM
Rons 5.3's Avatar
Anyone tried the ball-flange connectors from summitt? I think they are made by flowmaster. Im thinking of getting a set for my f-body.
Old Nov 8, 2006 | 02:58 PM
stone150's Avatar
i have 3 bolt flanges, but mine are leaking somewhere
Old Nov 9, 2006 | 12:53 AM
BigTex's Avatar
Ball and socket worked out great for me. With my Radix, I kept blowing out the gaskets on the 3-bolt flanges I started out with. I tried the soft aluminum ones that are supposed to seal up better, but they ended up melting.
Old Nov 9, 2006 | 10:25 AM
stone150's Avatar
how did the aluminum ones work till they melted? where did you get the ball and flange
Old Nov 9, 2006 | 11:48 AM
Rons 5.3's Avatar
The only ball and flange that i have seen so far is made by flowmaster, and summitt sells them. Ron
Old Nov 9, 2006 | 07:31 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
They stole the idea from a guy in Alabama. I have the original design sitting in a box in the garage. Turbogibbs knows who the guy is and his are a bit nicer.
Old Nov 10, 2006 | 02:03 PM
slammed1500's Avatar
i did the three bolt flanges on mine
works good 4 me
used a lil high heat paint on the welds almost looks like the coating
Old Nov 12, 2006 | 05:34 PM
LS1TRUCKGUY's Avatar
3 bolt flange with copper gaskets here. headers been on for about 1 year and no problems.
Old Nov 12, 2006 | 06:40 PM
Colby 04's Avatar
How many of you guys welded up your y-pipe? I've got all sorts of leaks in mine, considering doing flanges and just welding the joints. I'm using the band clamps, they worked well at first, but they developed leaks after things heat cycled.
Old Nov 12, 2006 | 10:18 PM
James B.'s Avatar
The copper gaskets are the only things that hold up for me. I tried the aluminum ones (melted) and the composite ones (blew out). The system I built is flanged in three places on each side and I use 3-bolt 3" copper gaskets between all of them.
