want to remove my HP sucker
Old Sep 8, 2003 | 04:23 PM
onyx's Avatar
14 Second Truck Club
Default want to remove my HP sucker
what is required in removing my mechanical fan?... shroud, and a socket????
what would i wire the electric fans into??
Old Sep 8, 2003 | 05:34 PM
BlownAlaskan's Avatar
Default Re: want to remove my HP sucker
I just put flex fans in over the weekend. The stock clutch fan was a breeze to get out. Just put a pair of vise-grips on the fan nut, and then hit the vise grips with some type of a soft blow hammer to pop the nut loose. Then you can just spin it off. Get the Flex-a-lite variable speed controller, it works very nicely. Hope this helps.
Old Sep 8, 2003 | 05:39 PM
onyx's Avatar
would i be able to bypass the clutch fan pulley, or does it run something else also..
Old Sep 8, 2003 | 05:43 PM
XLR8NSS's Avatar
Adkoonerstrator
The clutch fan pulley stays on, it runs the water pump. The end of it is threaded and that's what the fan nut screws onto. Here is a thread with a picture of it. You might need to wrap the belt like that if the pulley keeps spinning when you're trying to loosen the fan nut.
https://ls1tech.com/threads/showflat...rue#Post505884
Old Sep 9, 2003 | 12:09 AM
Flyer's Avatar
If you have an 18" crescent wrench, use that, and a rubber mallet. That will do the trick. If you can't get it to break loose, get a 2 lbs sledge or a ball pien hammer to hit the wrench with.
Taking the fan shroud off will help out too.
dsbodley
Nov 14, 2015 09:46 PM
cheyenne383
Nov 13, 2015 09:24 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
69z-28
Sep 21, 2015 07:31 AM
