Volant with Whipple??
Old Mar 27, 2004 | 02:23 PM
ranwalk's Avatar
Default Volant with Whipple??
Would a volant intake be better with my Whipple than the K&N fipk i'm using. I know it would bring in cooler air than the K&N, but how about actual air flow/volume??
Old Mar 27, 2004 | 02:24 PM
BlownChevy's Avatar
blownerator
25 Year Member
are you running a stock air box with a k&n?
Old Mar 27, 2004 | 02:26 PM
ranwalk's Avatar
Nope, i'm running a K&N fipk open filter intake
Old Mar 27, 2004 | 02:28 PM
BlownChevy's Avatar
blownerator
25 Year Member
Duhh, guess I should have read the whole post....
It will help a little....I have found that the K&N is a bit restrictive with boosted applications.
Old Mar 27, 2004 | 03:10 PM
onyx's Avatar
14 Second Truck Club
i suppose you could always customize the volant box, to accomodate your wanted air flow/volume...
Old Mar 27, 2004 | 03:22 PM
ranwalk's Avatar
True, what i like about the volant is the better heat insulation from the engine.That has to be better than the shield that comes with the fipk.
Old Mar 27, 2004 | 03:27 PM
onyx's Avatar
just cut out the bottom of the volant.. then you will have full advantage of the cold air plus the shielding from the heat.
Old Mar 29, 2004 | 05:09 AM
dkubricht's Avatar
Volant is coming out or is out with a thing plugs up under the box ans scoops air up from the inner airdam opening. Something like that
Old Mar 29, 2004 | 06:44 AM
2ksleeper's Avatar
I believe it is a toss up because the K&N fipk probably lets in more air as apposed to the volant letting in better quality air. If you choose to get the volant you will have to modify it to make it fit the whipple set-up and if you get the ram-air scoop with the volant it will let in road debri. To fix the road debri problem I had to make a pre-filter filter by adding some fine window screen to the ram-air scoop line. Just another thought, you can make the stock air box flow more by adding a k&n drop in & opening up the fender opening on the box & fender then adding a custom ram-air to the bottom.
gaps
Oct 15, 2015 02:53 PM
Lthompson
Oct 2, 2015 12:45 AM
nickrench3
Sep 17, 2015 08:48 AM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
