Volant with Whipple??
Originally Posted by ranwalk
Nope, i'm running a K&N fipk open filter intake
Duhh, guess I should have read the whole post....
It will help a little....I have found that the K&N is a bit restrictive with boosted applications.
Originally Posted by onyx
i suppose you could always customize the volant box, to accomodate your wanted air flow/volume...
I believe it is a toss up because the K&N fipk probably lets in more air as apposed to the volant letting in better quality air. If you choose to get the volant you will have to modify it to make it fit the whipple set-up and if you get the ram-air scoop with the volant it will let in road debri. To fix the road debri problem I had to make a pre-filter filter by adding some fine window screen to the ram-air scoop line. Just another thought, you can make the stock air box flow more by adding a k&n drop in & opening up the fender opening on the box & fender then adding a custom ram-air to the bottom.
gaps
Oct 15, 2015 02:53 PM
whippledstepside
Sep 17, 2015 05:02 AM
scooter k
Sep 16, 2015 10:32 PM
